SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,276 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
I did some backups and other updates and ran a myisamchk on the database.
Please let me know if you have any problems with the site ... (IMG:style_emoticons/default/type.gif) Andy |
Sparky |
Mahna Mahna! ![]() ![]() ![]() Group: Members Posts: 1,134 Joined: 21-June 03 From: Spencer, MA Member No.: 847 ![]() |
abbott295 |
Member ![]() ![]() Group: Members Posts: 237 Joined: 20-January 07 From: Georgia Member No.: 7,468 ![]() |
No problem for me, but as they say, your mileage may vary.
pete-stevers |
saved from fire! ![]() ![]() ![]() ![]() Group: Members Posts: 2,648 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest ![]() ![]() |
thanks Andy!
SirAndy |
"Hi my name is Sparky and I have a 914 problem." "No sir, i don't have a problem with |
Bartlett 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest ![]() |
I did some backups and other updates and ran a myisamchk on the database. Please let me know if you have any problems with the site ... (IMG:style_emoticons/default/type.gif) Andy Thanks Andy. Connection is faster on my computer. |
flipb |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,819 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region ![]() ![]() |
I did some backups and other updates and ran a myisamchk on the database. Please let me know if you have any problems with the site ... (IMG:style_emoticons/default/type.gif) Andy Did you change the oil while you were in there? Brad Penn? Adjust the valves? Long as we're at it, you should upgrade the stock oil pump. Your server will run 4% more efficiently!! Heck, while we're at it, you should put in a bigger master cylinder, maybe upgrade to 5-bolt hubs... Oh, wait. We'd all go nuts if the server had to be on jackstands for 12 months. |
SirAndy |
Did you change the oil while you were in there? Brad Penn? Adjust the valves? Long as we're at it, you should upgrade the stock oil pump. Your server will run 4% more efficiently!! Heck, while we're at it, you should put in a bigger master cylinder, maybe upgrade to 5-bolt hubs... Oh, wait. We'd all go nuts if the server had to be on jackstands for 12 months. I used rack-spacers when i mounted it. Does that count? (IMG:style_emoticons/default/confused24.gif) |
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
Rack spacers? I've seen those in the Victorias Secret catalog. (IMG:style_emoticons/default/w00t.gif)
DEC |
Senior Member ![]() ![]() ![]() Group: Members Posts: 632 Joined: 10-November 05 From: Rehburg Member No.: 5,104 Region Association: Germany ![]() ![]() |
Thanks Andy. Connection is faster on my computer. (IMG:style_emoticons/default/agree.gif) Gefühlt schneller |
EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
Thanks Andy. This site is awesome!
PanelBilly |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,907 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest ![]() ![]() |
I feel much better now. Maybe you should upgrade your name from Sir Andy to Dr. Andy
Katmanken |
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest ![]() |
Sor Ahndie,
Have you considered jumping the server as a method of getting the server restarted????? Attached image(s) ![]() |
SGB |
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States ![]() |
I've got a tip for her...
ericread |
The Viper Blue 914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California ![]() |
I've got a tip for her... Never stare directly at the sun? Errr, maybe that's not the tip you were indicating... (IMG:style_emoticons/default/idea.gif) |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Did you change the oil while you were in there? Brad Penn? Adjust the valves? Long as we're at it, you should upgrade the stock oil pump. Your server will run 4% more efficiently!! Heck, while we're at it, you should put in a bigger master cylinder, maybe upgrade to 5-bolt hubs... Oh, wait. We'd all go nuts if the server had to be on jackstands for 12 months. I used rack-spacers when i mounted it. Does that count? (IMG:style_emoticons/default/confused24.gif) that depends. Were they rubber spacers, or were they poly delrin? What hardness are they? Did you ream them out to fit? Rich |
Lo-Fi Version | Time is now: 31st July 2025 - 04:16 AM |
