Dam 914 still doesn’t start regularly |
Kevan |
Mar 22 2004, 09:15 PM
Newbie Group: Members Posts: 31 Joined: 5-December 03 From: Paso Robles,ca Member No.: 1,421 |
My 914 still doesn’t start regularly. I turn the key and every time I heir the buzz my guess is the D-Jet fuel pumping and then it might start or nothing happens. Once it starts cranking it will start just fine. Here is a list of what I’ve done. What am I missing??? What could be wrong?
New battery Clean the connections on the battery New ends on the positive wires to the battery New ignition switch Clean and replaced connections on the starter solenoid Cleaned ground strap connections from tranny to trunk Kevan |
TheCabinetmaker |
Mar 22 2004, 09:28 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Are you saying that nothing happens when you turn the key?
SirAndy |
Mar 22 2004, 09:32 PM
Resident German Group: Admin Posts: 41,681 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
starter is toast ...
i had the same problem. brand new starter fixed it. Andy |
weird_looking_cactus |
Mar 22 2004, 09:37 PM
Cactus Group: Members Posts: 225 Joined: 16-February 04 From: St, George UT Member No.: 1,660 |
I use to have this problem all the time and still have it today. I know for mine I was cranking mine over for to long and to many times in a row and the starter gets really hot. and the life span goes down alot. But over all if you take it out and bring it to someone to test the problem may be that is drawing to many watt's away that is what my problem was then I got a new one stuck it in and it work fine for the first few days but I screwed this one up to by just over using it.
Kevan |
Mar 22 2004, 10:02 PM
[QUOTE] Are you saying that nothing happens when you turn the key?
Only the d-Jet pumping fuel "starter is toast ..." How could the starter be toast because when it ever decides to crank it fires right up. Anyway I think I have an extra starter. I'll put it in and see what happens. Thanks Kevan |
nebreitling |
Mar 22 2004, 10:16 PM
Member Emeritus Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 |
mightyohm |
Mar 22 2004, 10:41 PM
Advanced Member Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
Could be the solenoid contacts too. I went through this too.
I put in a rebuilt starter AND a relay kit. No more problems. |
TROJANMAN |
Mar 23 2004, 03:36 PM
Looks nice in pictures......... Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
i know you guys are all saying starter, but could it be a bad fuel pump? with my 914, i used to get a buzzing sound when i turned the key, but it wouldn't consistenly start. one day, it didn't start at all. turned out it was a bad fuel pump. replaced that and i had no problems. until.............we won't get into that right now.
Dave Bell |
Mar 23 2004, 04:08 PM
Member Group: Members Posts: 234 Joined: 27-November 03 From: Santa Clarita, CA Member No.: 1,398 Region Association: None |
I was just posting something on this on Rennlist... so here is a diagram followed by photos of a relay set up for your starter.
- Dave Attached thumbnail(s) |
Dave Bell |
Mar 23 2004, 04:09 PM
Photo 1
Dave Bell |
Photo 2
SirAndy |
Mar 23 2004, 04:15 PM
QUOTE(Dave Bell @ Mar 23 2004, 02:08 PM) so here is a diagram followed by photos of a relay set up for your starter. thing about the relays is, you just put a band-aid on a problem you can't find. will work (at least for a while) but won't fix what's actually broken. if in good working order, the starter circuit doesn't need a relay ... Andy |
Dave Bell |
Mar 23 2004, 04:51 PM
Bandaid?... maybe...
Lots of things that aren't needed are still an improvement. IMHO any circuit in a car that draws a fair amount of current is improved when you add a relay, unless you like lots of current running through switches on your dash or in the key switch...... bonus is less voltage drop to the starter... In my case I never had a problem with that starter again... didn't have to buy another starter... If you need a new starter... buy one... then add a relay and save your 30 year old key switch. |
SirAndy |
Mar 23 2004, 05:07 PM
QUOTE(Dave Bell @ Mar 23 2004, 02:51 PM) In my case I never had a problem with that starter again... didn't have to buy another starter... yes, that's what i call a bandaid (IMG:style_emoticons/default/wink.gif) so, your starter was giving you problems cause it wasn't getting enough juice to turn nicely. you added a relay to give it moah power. worked great. still didn't fix the problem of not getting enough juice to it without the relay tho. <_< somewhere in there you still have a little electrical gremlin lurking ... that was my point. bandaid, here, i said it again. the circuit was designed to work without a relay. if you need one, something IS wrong. Andy |
Joe Bob |
Mar 23 2004, 05:10 PM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
Cactus....it's amps, not watts......
As to starting...it's normal to hear a fuel pump buzz....no buzz no pump. Some fuel pumps will have intermittent shorts that will work once the engine is running. That's why it will start after a few cranks....it is using the residual pressure in the fuel system..... Now a starter that drwas a lot of AMPS will heat due to impedance in the wiring. This can be from bad grounds or corrosion in the postives leads..... Best to check the wiring before replacing expensive, non-returnable electrical components.... |
Brad Roberts |
Mar 23 2004, 07:51 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Hey Kevan...
That 6 mount you looked at was ordered for you... B |
mightyohm |
Mar 23 2004, 10:28 PM
QUOTE(SirAndy @ Mar 23 2004, 02:15 PM) QUOTE(Dave Bell @ Mar 23 2004, 02:08 PM) so here is a diagram followed by photos of a relay set up for your starter. thing about the relays is, you just put a band-aid on a problem you can't find. will work (at least for a while) but won't fix what's actually broken. if in good working order, the starter circuit doesn't need a relay ... Andy Andy, normally I would agree with you, but the starter circuit pulls SEVERAL AMPS through a tiny wire that goes more than a couple feet up to the front of the car, then through an ordinary ignition switch. This is a bad design. There are bandaids, and there is also lack of margin in engineering design. This is a little of both. |
SirAndy |
Mar 23 2004, 10:35 PM
QUOTE(jkeyzer @ Mar 23 2004, 08:28 PM) This is a bad design yes. maybe. still, it works well if in good working order. point is (still), if it's not working right, something is wrong!!! whatever the problem is, fix it first, THEN install a relay if you wish ... Andy |
mightyohm |
Mar 23 2004, 11:47 PM
I will let you know when my ignition switch (or whatever it is that is going bad) craps out, but it's been 6 months now and not a single failed start.
Brad Roberts |
Mar 23 2004, 11:54 PM
Band-Aid. Fix the problem. Ranks right up there with people that run extra wires because something doesnt work instead of fixing the actual problem.
Yes a relay works.. I have also seen them do ZERO after being installed. No matter what happens the little yellow wire has to supply voltage to the starter solenoid. If it isnt enough then there is a issue between the ignition switch and the starter. FIX IT. I even had a reputable shop tell me they install relays with every starter purchase so people with old 911's/914's dont return with a starting problem later. They know the real issue lay's in the ignition switch but people wont pay to have it done correctly... Band-Aid. B |
Lo-Fi Version | Time is now: 11th June 2024 - 09:56 AM |
