WTB 5 lug rear hubs, for 5 lug conversion |
DanT |
Feb 24 2010, 02:06 PM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
either already drilled for 5 lug or a good set of 4 lug hubs ready to be drilled.
Prefer a set of early hubs with the reinforcing gussets. thanks (IMG:style_emoticons/default/smile.gif) |
Randal |
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
either already drilled for 5 lug or a good set of 4 lug hubs ready to be drilled. Prefer a set of early hubs with the reinforcing gussets. thanks (IMG:style_emoticons/default/smile.gif) I have a pair. 5 lug with long studs |
DanT |
Feb 24 2010, 02:18 PM
either already drilled for 5 lug or a good set of 4 lug hubs ready to be drilled. Prefer a set of early hubs with the reinforcing gussets. thanks (IMG:style_emoticons/default/smile.gif) I have a pair. Hi Randal, are they already drilled and are they the ones with the gussets? how much $? (IMG:style_emoticons/default/smile.gif) |
jesiv |
Feb 24 2010, 02:19 PM
Senior Member Group: Members Posts: 552 Joined: 5-August 07 From: Pensacola/Milton, Florida Member No.: 7,975 Region Association: Northern California |
I have a pair of trailing arms with them already installed. All freshly painted!
Randal |
Feb 24 2010, 02:32 PM
either already drilled for 5 lug or a good set of 4 lug hubs ready to be drilled. Prefer a set of early hubs with the reinforcing gussets. thanks (IMG:style_emoticons/default/smile.gif) I have a pair. Hi Randal, are they already drilled and are they the ones with the gussets? how much $? (IMG:style_emoticons/default/smile.gif) They are drilled for 5 bolt conversion, I don't know think they have gussets, but look at the picture I put in. Studs are 103mm. |
DanT |
Feb 24 2010, 02:33 PM
I have a pair of trailing arms with them already installed. All freshly painted! $ ?(IMG:style_emoticons/default/smile.gif) and where in Norcal are you located? |
Randal |
Feb 24 2010, 02:35 PM
I have a pair of trailing arms with them already installed. All freshly painted! $ ?(IMG:style_emoticons/default/smile.gif) and where in Norcal are you located? I live in Los Altos Dan. Remember? |
DanT |
Feb 24 2010, 02:38 PM
I have a pair of trailing arms with them already installed. All freshly painted! $ ?(IMG:style_emoticons/default/smile.gif) and where in Norcal are you located? I live in Los Altos Dan. Remember? I know where you live Randal (IMG:style_emoticons/default/biggrin.gif) I was asking the other poster.... How much do you want for them? these will be going on a '75 I am going to build into a PAX contender (IMG:style_emoticons/default/smile.gif) |
Randal |
Feb 24 2010, 02:45 PM
I have a pair of trailing arms with them already installed. All freshly painted! $ ?(IMG:style_emoticons/default/smile.gif) and where in Norcal are you located? I live in Los Altos Dan. Remember? I know where you live Randal (IMG:style_emoticons/default/biggrin.gif) I was asking the other poster.... How much do you want for them? these will be going on a '75 I am going to build into a PAX contender (IMG:style_emoticons/default/smile.gif) With or without the long ($9.00 each) studs? |
DanT |
Feb 24 2010, 02:51 PM
Randal,
without the long studs...I am just mounting some 6" cookies or Fuchs without spacers. (IMG:style_emoticons/default/smile.gif) |
Randal |
Feb 24 2010, 03:09 PM
Randal, without the long studs...I am just mounting some 6" cookies or Fuchs without spacers. (IMG:style_emoticons/default/smile.gif) So is $75 for the pair, without the studs, fair? |
DanT |
Feb 24 2010, 03:16 PM
Randal, without the long studs...I am just mounting some 6" cookies or Fuchs without spacers. (IMG:style_emoticons/default/smile.gif) So is $75 for the pair, without the studs, fair? SOLD Randal (IMG:style_emoticons/default/biggrin.gif) you happen to have the rear rotors that work with those? (IMG:style_emoticons/default/idea.gif) |
Randal |
Feb 24 2010, 03:23 PM
Randal, without the long studs...I am just mounting some 6" cookies or Fuchs without spacers. (IMG:style_emoticons/default/smile.gif) So is $75 for the pair, without the studs, fair? SOLD Randal (IMG:style_emoticons/default/biggrin.gif) you happen to have the rear rotors that work with those? (IMG:style_emoticons/default/idea.gif) I think so... will need to look. |
DanT |
Feb 24 2010, 03:25 PM
completely cool (IMG:style_emoticons/default/biggrin.gif) If they aren't too worn I would like them as well if you have them. (IMG:style_emoticons/default/sawzall-smiley.gif)
Randal |
Feb 24 2010, 03:33 PM
completely cool (IMG:style_emoticons/default/biggrin.gif) If they aren't too worn I would like them as well if you have them. (IMG:style_emoticons/default/sawzall-smiley.gif) Yup I do have them. I only took them off to put a set of 914 -6 fronts on the back. They are in great shape and have been on the car since Bontempi converted it to a 5 lug. I'll take a picture as soon as my camera battery is charged. |
DanT |
Feb 24 2010, 03:36 PM
completely cool (IMG:style_emoticons/default/biggrin.gif) If they aren't too worn I would like them as well if you have them. (IMG:style_emoticons/default/sawzall-smiley.gif) Yup I do have them. I only took them off to put a set of 914 -6 fronts on the back. They are in great shape and have been on the car since Bontempi converted it to a 5 lug. I'll take a picture as soon as my camera battery is charged. thanks, now I just need to get a new set of front rotor drilled for 5 lug and I am ready to go.... (IMG:style_emoticons/default/clap56.gif) |
Randal |
Feb 24 2010, 03:42 PM
completely cool (IMG:style_emoticons/default/biggrin.gif) If they aren't too worn I would like them as well if you have them. (IMG:style_emoticons/default/sawzall-smiley.gif) Yup I do have them. I only took them off to put a set of 914 -6 fronts on the back. They are in great shape and have been on the car since Bontempi converted it to a 5 lug. I'll take a picture as soon as my camera battery is charged. thanks, now I just need to get a new set of front rotor drilled for 5 lug and I am ready to go.... (IMG:style_emoticons/default/clap56.gif) Sorry Dan, I have the calipers, not the rotors. |
DanT |
Feb 24 2010, 04:23 PM
completely cool (IMG:style_emoticons/default/biggrin.gif) If they aren't too worn I would like them as well if you have them. (IMG:style_emoticons/default/sawzall-smiley.gif) Yup I do have them. I only took them off to put a set of 914 -6 fronts on the back. They are in great shape and have been on the car since Bontempi converted it to a 5 lug. I'll take a picture as soon as my camera battery is charged. thanks, now I just need to get a new set of front rotor drilled for 5 lug and I am ready to go.... (IMG:style_emoticons/default/clap56.gif) Sorry Dan, I have the calipers, not the rotors. no problem, thanks for looking I will just get a new set of front and rear 4 lug rotors and have them drilled for the 5 lug setup. I will give you a call about picking up the hubs. do you remember who did the drilling of the rotors when you had your car converted. I guess I can take them to Jay (IMG:style_emoticons/default/smile.gif) |
Randal |
Feb 24 2010, 06:13 PM
completely cool (IMG:style_emoticons/default/biggrin.gif) If they aren't too worn I would like them as well if you have them. (IMG:style_emoticons/default/sawzall-smiley.gif) Yup I do have them. I only took them off to put a set of 914 -6 fronts on the back. They are in great shape and have been on the car since Bontempi converted it to a 5 lug. I'll take a picture as soon as my camera battery is charged. thanks, now I just need to get a new set of front rotor drilled for 5 lug and I am ready to go.... (IMG:style_emoticons/default/clap56.gif) Sorry Dan, I have the calipers, not the rotors. no problem, thanks for looking I will just get a new set of front and rear 4 lug rotors and have them drilled for the 5 lug setup. I will give you a call about picking up the hubs. do you remember who did the drilling of the rotors when you had your car converted. I guess I can take them to Jay (IMG:style_emoticons/default/smile.gif) Jay could definately handle it; be sure to take the rotors along with the hubs. Btw I also found a pair of 4 bolt hubs, if you need them. Jay is looking for work, so would be happy to see you. I'll get the studs pressed out of mine this Friday. I'll be down at Aaron's new shop in Gilroy working on 222, or what is left of her. I could call you on the way back and we could meet on 85 somewhere. |
DanT |
Feb 24 2010, 06:26 PM
Randal,
Joanne and I may be going away this Friday for the weekend in the RV, so I will let you know. Just give me a call when you are going to be down in Gilroy. If it is raining on Friday Am then we will probably just stay home. Sitting in the RV with two dogs when it is raining outside is not a great time (IMG:style_emoticons/default/sad.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 02:19 AM |
