Head light wiring for GT head lights, Can I just seal up all the motor and relay wires? |
FourBlades |
Mar 15 2010, 07:57 PM
From Wreck to Rockin Group: Members Posts: 2,055 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
I want to eliminate the head light motors and relays. I heat shrinked all the
connectors on the wiring going to the relays and motors to stop them from grounding. My head lights are not lighting, so I am wondering if I need to jumper any of the motor or relay wiring to keep my head lights working? I am not familiar with the innards of the headlight switch and it is connected to everything in the front of the car so I thought this could be possible. Thanks, John |
VaccaRabite |
Mar 15 2010, 08:38 PM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I think you just sealed up your ground, is all.
Zach |
FourBlades |
Mar 15 2010, 08:47 PM
From my wiring diagram it seems like the headlights have their own ground, but I will check on that. John |
FourBlades |
Mar 16 2010, 11:19 AM
turnaround89 |
Mar 16 2010, 11:46 AM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
Are you just trying to get the lights to turn on, and thats it? if thats the case there are three wires that need to the lights...power for highs, power for lows, and ground...when we rewired my car thats how we did it, reused the old connector as well. However, we did not use the stock switch like you mentioned you are. So i don't know how that switch works either
Lo-Fi Version | Time is now: 8th June 2024 - 06:35 PM |
