Engine Not Running Right, Appears to be running on 2 cylinders?? |
LotusJoe |
Apr 9 2010, 10:24 PM
Europa Twink Driver Group: Members Posts: 406 Joined: 30-November 09 From: Southern California Member No.: 11,085 Region Association: Southern California |
I removed all the tins and blower case to clean the cylinder fins and head fins, and replaced the oil cooler seals. I also changed the plugs, points, rotor, cap, and plug wires. Put everything back together and started it up. Set the timing and the engine appears to run correctly. I got out my Raytech temperature gun to check the exhaust pipe temps at the head. Cylinders 1 and 3 run about 450 degrees at the exhaust pipe where it connects to the head. Cylinders 2 and 4 are running 140 degrees. This tells me there is no fire in Cylinders 2 and 4.
Not sure on where to start checking. I'm thinking 2 and 4 are not getting fuel? Could there be a problem with the control module in the bottom of the distributor? If so how do I check it? A few months ago I did a compression check and got 165 on all four cylinders. Engine idles fine and revs smoothly. It's on a test bench so obviously there is no load on the motor. Would it run smooth on just cylinders 1 and 3? |
Dave_Darling |
Apr 10 2010, 12:08 AM
The injectors are "banked" 1&4 and 2&3. Each bank is controlled by one of the trigger point contacts.
Are the front and rear injector wires swapped on one side? You can find pin numbers on the wires, at least near the ECU connector, and you can also just count the pins on the connector. If there aren't numbers on the wires near the injector, you may need to pull the connector off the ECU and check which wire is plugged into which injector. If it's both front cylinders, I'd suspect a cam problem. (IMG:style_emoticons/default/sad.gif) Check the compression to see if those two cylinders have much lower compression than the rear two, if so I would definitely suspect the cam. I believe the injectors are grounded with 1&2 together and 3&4 together, so a ground issue would not fit your case unless someone has rewired the FI wiring harness. Oh, another possibility, especially since you were just mucking around with the ignition system: The distributor cap might not be on correctly, or the ignition points might be messed up somehow. It's often worthwhile to go back and re-check everything you touched since the last time the engine ran nicely... Check the compression, verify the wires, and get back to us. --DD |
Tom |
Apr 10 2010, 08:52 AM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Your cap is wire different than mine (90 dergees different). Number one, I think, should come out of the cap just to the rear of the vacuum can on the dissy. Then going clockwise for firing order. Maybe your timing is different?
Tom |
LotusJoe |
Apr 10 2010, 08:59 AM
Your cap is wire different than mine (90 dergees different). Number one, I think, should come out of the cap just to the rear of the vacuum can on the dissy. Then going clockwise for firing order. Maybe your timing is different? Tom Would it even run if I was 90 degrees out (IMG:style_emoticons/default/confused24.gif) |
Tom |
Apr 10 2010, 09:10 AM
OK, just went and looked. It seems your #1 is opposite the vacuum can. 180 degrees out.
Tom |
LotusJoe |
Apr 10 2010, 10:23 AM
ClayPerrine |
Apr 10 2010, 10:37 AM
Life's been good to me so far..... Group: Admin Posts: 15,503 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
From experience, if you swap two plug wires that are 180 degrees apart on the distributor, it will run, but it will run only on 2 cylinders. Double check the plug wires.
Simple plug wire setup. The right front distributor tower hooks to the right front cylinder. The right rear distributor tower hooks to the right rear cylinder. The left front distributor tower hooks to the left rear cylinder. And the left rear distributor tower hooks to the left front cylinder. |
Tom |
Apr 10 2010, 12:23 PM
Clay is right on. And from your pic, it looks like you have 1+4 swapped. Tom |
LotusJoe |
Apr 12 2010, 01:06 PM
Thanks to all who responded. I had plug wires 2 and 4 reversed. Engine runs much better now (IMG:style_emoticons/default/aktion035.gif)
Now dealing with high idle problem. And I think its running lean. Exhaust temperature seems high. I'm using my Ray-tech gun to measure temeratures at the exhaust pipes where they bolt to the heads. Temps are running around 650 degrees. Temperture at the head temp sensor is only about 200 degrees. Oil cooler is running less than 200 dergrees. Not really sure what temp I should see at the exhaust pipes (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 2nd June 2024 - 03:09 PM |
