jeffdon |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None ![]() |
Do I use this part still with the 911 mounts?
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,188 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
And your probably going to have to slot the mounting holes a little to get them in.
jeffdon |
underthetire |
The mount is easier (IMG:style_emoticons/default/biggrin.gif)
Just giving you a heads up so you can get the dremel out. |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Don't forget the 'cup' and thick washer. Here's everything in order.
Attached image(s) ![]() |
jeffdon |
Jerry75914 |
Member ![]() ![]() Group: Members Posts: 124 Joined: 13-October 08 From: Half Moon Bay, CA Member No.: 9,640 Region Association: Northern California ![]() |
Don't forget the 'cup' and thick washer. Here's everything in order. Yep, figured on those, but thanks anyhow. For some reason, my dremel and i are on lousy terms. I did it with a round metal file and some grimacing. The previous post is dead on, you will need to open up the holes just a bit for them to fit. I did it just last year. Good luck! |
Lo-Fi Version | Time is now: 11th July 2025 - 05:10 PM |
