> 911 rear hubs with 944 stub axles ?, is anyone using this combination ?
sechszylinder
post Apr 2 2004, 02:23 AM
Hi folks,
I heard rumors, that you can use stub axles from a later modell 944 (944 s2 or 944 turbo) in combination with early 911 rear hubs.
The trick is , that the splines of the 944 stub axle fits into the early 911 hubs. On the other side it should be possible
to use the outer cv-joints of the same 944 modell which provides splines for the 914/4 axles.
That would be a very cheap alternative to the expensive 914/6 stub axles ...
does anyone is using this combination ?
here's a small sketch of the proposed setup :
greetings ...
Benno
dakotaewing
post Apr 2 2004, 08:16 AM
Bump.....
Brad, Mueller, JP, Gint, Kevin, anybody....???????????????
Thom
JFJ914
post Apr 2 2004, 11:24 AM
QUOTE(sechszylinder @ Apr 2 2004, 12:23 AM)
Clay Perrine from Rennlist wrote this a while ago:
"The rear hub used on a 914/6 is the same as the one used on the 69-73 911. The stub axle is a custom part. The CV axle is the same length as a /4, but it uses a different splined axle shaft and CV joint.
Here's a way to get a 5 lug conversion on the rear without ANY machining or finding the pircey 914/6 rear hubs. Get 69-73 911 rear hubs. Get the axles complete with the stub axles from a 944 turbo with the ALUMINUM trailing arms. The splines on the 944 turbo stub axles fit the 69 911 flanges, and they are the correct length. Remove the CV joints from the 944 axle and discard the axle. Put the 944 CV joint on to a 914/4 drive shaft. The 944 CV joint internal splines are the same as the 914/4 axle. Find a 915 transaxle from about a 75 911, and remove the drive flanges from it. If you got the correct ones, they will match the 944 CV joints and will bolt onto the 914 transaxle.
The extra bonus to this is you get beefier CV joints. This may benefit the V8 guys."
Clay
"911 half shafts will work, provided you NEVER let the suspension come to full droop or full compression. If you do, the CV joints bottom out at max extension and that WILL damage them. To make it work correctly you have to add a 1" spacer on one end of the axle.Wes Hildreth and I discussed this at length, and we measured a 911 axle and a 914 axle. He is the one that found the combo of 944 and 911 parts that I sent out, for that very reason."
Clay Perrine
I think you wind up with 100mm c/v's just like an SC+.
Does anyone know if the later hub centric hub fit into the 914 rear bearing?
John Jentz
dinomium
post Apr 2 2004, 11:47 AM
Git on a chair son, all the good stuff is goin over yer head!
Unless you are doing an engineering project, wouldn't it just be easier and cheaper (in the long run---time=$$$) to just buy the correct 914-6 stub axle?
http://www.mittelmotor.de/webshop/englisch...bestellung.html has them for under $190 each. Has anyone bought them? or From them?
tat2dphreak
post Apr 2 2004, 12:09 PM
stoya, stoya, stoya
don't know... bet shipping would be the KILLER!!
echocanyons
post Apr 2 2004, 12:26 PM
What exactly does this mean? I just finished my rear setup using 911 axels out to the hubs.
Does this mean that my CV's will bottom out on the trailing arm? I really cant understand a situation that would make this possible (but what do i know)
JFJ914
post Apr 2 2004, 12:49 PM
QUOTE(echocanyons @ Apr 2 2004, 10:26 AM)
He means that when the axles are at max extension the C/V's are still being pulled apart beyond max extension. I have also read that this is not true as the 911 joints are thicker. Did you compare max compression and max extension lengths between the 914's and 911's before you mounted them? If not, jack the car up and see if the axle shafts have any play(back and forth slop) at full droop. Whatever you find there will probably be the same as when the shock at full compression.
Report back! (IMG:style_emoticons/default/smile.gif)
dinomium
post Apr 2 2004, 03:53 PM
QUOTE(tat2dphreak @ Apr 2 2004, 10:09 AM)
under 15kgs is 79 Euros... 99 Euros for over.
echocanyons
post Apr 2 2004, 04:32 PM
I guess extension is the key word.
Brad stated, in the past, in at least one post that this is not a problem.
Brad, can you reaffirm this?
tat2dphreak
post Apr 2 2004, 04:35 PM
stoya, stoya, stoya
QUOTE(dinomium @ Apr 2 2004, 03:53 PM)
THAT is a killer! many of the parts seem cheaper than here, but with the shipping, you pay a lot more!
Jeroen
post Apr 2 2004, 06:36 PM
Region Association: Europe
QUOTE(tat2dphreak @ Apr 2 2004, 11:35 PM)
Yeah... welcome to my world (IMG:style_emoticons/default/headbang.gif)
cheers,
Jeroen
sechszylinder
post Apr 3 2004, 01:36 AM
QUOTE(dinomium @ Apr 2 2004, 09:47 AM)
14-6 stub axle?
no, cause i'm the lucky one who can get a pair of those 944 s2 stub axles for about 50 euros ...
benno
dinomium
post Apr 3 2004, 10:05 AM
That is a great $$. I had to check the conversion rate... What do you think your total outlay will be for your project? The other beni would be that you can use all 914 CVs and axles with the NOS stuff.
Do keep this post going with your satus, Benno!
jonwatts
post Apr 3 2004, 11:15 AM
no rules, just wrong
QUOTE(sechszylinder @ Apr 2 2004, 11:36 PM)
That's the whole problem. I really like the idea of using all OEM parts for a 5 lug setup; but if you don't have access to these semi-rare and usually expensive parts then you're much better off just using redrilled and studded 4-lug hubs. You know the ones most of us use and have never heard of failing.
I have become a big fan of "do it right" instead of my old ways of "do it cheap" which usually lead to "do it over" but you have to draw the line somewhere. Otherwise you end up with a perfect 914 that cost you $75k and that's just stupid.
- Lo-Fi Version Time is now: 15th June 2026 - 03:59 PM
