> what are the differences between a 73 and 74 2.0 engine
crxnug
post May 17 2010, 06:16 PM
are there any differences between a 1973 and 74 2.0 engine,? are parts interchangeable, are there differences in the fuel injection? and info would be much appreciated
McMark
post May 17 2010, 06:20 PM
914 Freak!
Not much. Are you looking for information regarding running a stock motor? Or in terms of a rebuild core?
For a rebuild core, they are the same.
Tom_T
post May 17 2010, 06:31 PM
TMI....
QUOTE(crxnug @ May 17 2010, 05:16 PM) *
Mostly differences at the earlier MPS, CHT, ECU & other EFI components - otherwise they're the same basic GA engine 73 & 74, as McMark said. So you could transplant the appropriate MY's D-jet set-up if you're looking for a new engine/core, but save the old one if it's a matching number original engine to the car!
JRust
post May 17 2010, 07:41 PM
Yeah the same but for the Fuel Injection. You don't want to mix the FI between the years. Also don't mix the wiring between them. Dont ask me how I know (IMG:style_emoticons/default/dry.gif)
underthetire
post May 17 2010, 07:43 PM
one year (IMG:style_emoticons/default/piratenanner.gif)
JeffBowlsby
post May 17 2010, 08:12 PM
Then '74 is by far the better engine...:tongue in cheek:
Actually there are few subtle and meaningless differences:
The 74 has:
1 year less wear...
Single port throttle body, no throttle shaft spring
Charcoal canister relocated to the engine bay (@ mid-year 74)
Some, not all, FI components were changed for the 74 model as mentioned above
Thaz all...
detoxcowboy
post May 17 2010, 08:54 PM
Region Association: Africa
For a more detailed of what changed and what is inter changeable and what is preferd.. link below
http://members.rennlist.com/pbanders/DJetParts.htm
The main thing is if your using the 037 ecu from '73 then you must use the corresponding cht w/ resistor and mps.. that really is the only major rule..
change the ecu to 74-76 and the fi components are alot more flexible.. 74 stock is a good bet as then you can go alot of ways when in need for a part. anything more than that will just confuse your question.. read that link it will be your best guide..
- Lo-Fi Version Time is now: 2nd May 2026 - 12:18 PM
