WTB; Plug End for defrost at relay board... |
detoxcowboy |
May 24 2010, 02:48 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
WTB; Plug End (connector piece) for rear window defrost at relay board...
type47 |
May 24 2010, 04:30 PM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
hmm, never seen one! (IMG:style_emoticons/default/idea.gif)
detoxcowboy |
May 24 2010, 06:08 PM
It is just a factory dual bullet connection, i saw one then did not want to buy the harness at the time, i rewired it up my self, works fine but for posterity would like to buy the factory fittement,, |
type47 |
May 25 2010, 06:54 AM
any pix?
detoxcowboy |
May 25 2010, 08:01 AM
No picture, on the realy board there is an 2 prongs that take a connecor for the rear window defrost.. also an extra spot for a standard 5 prong relay that operates as a switch for that connection to the rear window defrost..
IN this diagram it is the connector plug for the yellow and red stripe wire and green wire in the upper left corner just above relay #52 and next to the 2 fuses in the holder.. |
jim_hoyland |
May 25 2010, 09:00 AM
Get that VIN ? Group: Members Posts: 9,317 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Here's a picture that may help, someone probably has one and didn't know what it's for. Good Luck
Attached image(s) |
jim_hoyland |
May 25 2010, 09:02 AM
One more..
Attached image(s) |
detoxcowboy |
May 25 2010, 10:38 PM
(IMG:style_emoticons/default/drunk.gif) (IMG:style_emoticons/default/beerchug.gif) Jake Oduole came through stong!! Got it..
type47 |
May 26 2010, 09:26 AM
Nice pix of a part I'd never seen before. The plug is even keyed!
Lo-Fi Version | Time is now: 5th June 2024 - 12:54 PM |
