| adambo |
May 31 2010, 10:40 PM
Newbie ![]() Group: Members Posts: 25 Joined: 8-September 09 From: Boulder, Colorado Member No.: 10,776 Region Association: Rocky Mountains |
I have my motor sitting on the floor and I'm trying to start it, with a strong battery the starter can't get it spinning fast enough to start. The tranny is in gear and i think thats the problem, how do I get it into neutral?
-Adam |
| detoxcowboy |
Jun 1 2010, 08:03 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
neutral is in the center postion 90 deg from the tranny.
| EdwardBlume |
Jun 1 2010, 08:10 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,340 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California
The gear selector will also move up and down freely which is the play for neutral...
| underthetire |
Jun 1 2010, 10:13 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Are you using jumper cables to try to start it?
| adambo |
Jun 1 2010, 02:23 PM
I'm using a strong battery with one of those battery chargers and I took the belt off the alternator. Any advice? Also I found neutral but its weird, I can spin the CVs by hand and the motor doesn't turn over, but while still in neutral when I hit the starter the CV's still spin.
| underthetire |
Jun 1 2010, 02:30 PM
Again, are you using jumper cables, from your battery to the starter?
| adambo |
Jun 1 2010, 02:33 PM
No, sorry I misunderstood you. I pulled the actual cables from the car.
| jaxdream |
Jun 2 2010, 07:19 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
It's normal for the trans output flanges to turn when in neutral , the is no weight from the car on the suspension holding the cv / axle shafts / wheels and tires in place . You didn't mention if the motor was rebuilt or not , running before the motor pull , what condition of tune , carbs or stock f inection. More info will get a bigger picture.
Jack / Jaxdream |
| underthetire |
Jun 2 2010, 08:21 AM
Lo-Fi Version | Time is now: 26th August 2026 - 07:18 AM |
