FS: 1973 914 2.0 fresh restoration |
boxstr |
Jun 6 2010, 11:32 AM
MEMBER:PACIFIC NORTHWEST REGION Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest |
1973 914 Porsche 914 2.0
Eight year restoration of 1973 Porsche 914 with 2.0 liter engine with D-tronic ignition. 81,485 miles. This car runs and drives EXCELLENT. Original front and rear anti-sway bars. New Schafer clutch, pressure plate with new throw out bearing. Recent professional tune-up and valve adjustment. Engine recently removed by Mountain View Imports, Bend, Oregon to install new front engine front seal and oil cooler seals (German-made for longevity). No engine leaks. Hugh at Mountain View Imports says this 914 is one of the best running 914's he's worked on. Past years have replaced rear engine seal and valve push rod seals. New temperature sending unit and engine temperature sensor. New engine throttle cable. Body sanded, primed and professionally painted by Prineville Body & paint; original Porsche Ivory White. Owner did most of prep work for painting. Entire car re-painted, including front and back trunks and engine bay. Black satin paint on targa roof. Front, back, and side valances removed primed and also painted satin black. Entire bottom of unibody sanded, primed and sprayed with rubber coating by owner. New engine tray and support. Original Italian Pedrini chrome wheels with good Kelly radials. Riviera wheels included with car.Bucket seats upholstered with built-in lumbar for comfort ; roll bar and front window trim recovered in black leather by Red Hot Interiors, Bend, OR. Camp 914 fog lights. Fuel tank removed and boiled. Stainless steel fuel lines by Tangerine Racing; fuel lines installed from fuel tank to engine. All gauges and trip meter work. New windshield and dash cover. Custom made instrument console with built-in sub-woofer, ready for stereo. New antenna. New master brake reservoir and hose. Fuel pump in front with original steel cover. Recent wheel alignment. Optima battery and hot start relay kit. New bilstien rear shocks, poly sway bar bushings. New 914 100 lb stock springs; Stainless steel DOT brake lines; 911 brake master cylinder; German made inner and outer window fuzzy seals; upper roll bar seals. New Bosch alternator and pulley belt. New Monza exhaust with "Allen wrench" exhaust bolts. Contact Craig at 503-799-5794 Well priced at $9250.. Obo. Attached image(s) |
boxstr |
Jun 14 2010, 09:52 PM
Back on the Market
boxstr |
Jun 25 2010, 11:05 AM
New price $9250.obo.
boxstr |
Jun 30 2010, 09:40 PM
New
boxstr |
Jul 1 2010, 12:22 PM
[quote name='boxstr' date='Jun 30 2010, 08:40 PM' post='1337624']
boxstr |
Jul 1 2010, 12:23 PM
bembry |
Jul 2 2010, 06:11 AM
Senior Member Group: Members Posts: 529 Joined: 29-July 05 From: Bakersfield, CA Member No.: 4,499 Region Association: MidAtlantic Region |
Absolutely beautiful. If I didn't already have my own 73 2.0 in light ivory, I'd be all over this!
boxstr |
Jul 11 2010, 07:33 PM
Sold.....!
Lo-Fi Version | Time is now: 8th June 2024 - 11:34 AM |
