throttle hangs up, between shifting |
elsargento |
Jun 7 2010, 10:44 AM
Newbie Group: Members Posts: 44 Joined: 9-September 06 From: Topanga, California Member No.: 6,802 |
I'm not sure what is causing my throttle to hang up. I checked the cable and when I let up on the pedal it all returns to normal. Seems like when I'm shifting if I let up on the pedal real fast it drops the revs to normal. Cable seems free. Could the tps be hanging up idles fine and just seems to be an intermittent problem.
tradisrad |
Jun 7 2010, 10:53 AM
Senior Member Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
is the throttle cable wrapped around the clutch cable (in the tunnel near the pedal cluster)
jt914-6 |
Jun 7 2010, 11:22 AM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
is the throttle cable wrapped around the clutch cable (in the tunnel near the pedal cluster) (IMG:style_emoticons/default/agree.gif) Put the car in neutral and push in on the clutch pedal. Does the engine rev up??? If so, the cable is around the clutch cable.... |
Lo-Fi Version | Time is now: 10th June 2024 - 01:04 PM |
