Decel Valve on 1974 2.0 FI, Do I need one |
motomadness1947 |
Jun 8 2010, 02:12 PM
Newbie Group: Members Posts: 35 Joined: 9-May 10 From: smyrna, tn Member No.: 11,709 Region Association: None |
I just bought some very needed new vacuum hoses for my newly acquired 2.0 fuely.
Before I drive it at all I need to do quite a bit of work, but to get to the point, someone has removed the DECEL Valve. Do I need one for performance or is it an early attempt at emissions control. Should I just plug each one of the vacuum hose nipples leading to the decel valve. Thank you (IMG:style_emoticons/default/chair.gif) |
SirAndy |
Jun 8 2010, 02:45 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I just bought some very needed new vacuum hoses for my newly acquired 2.0 fuely. Before I drive it at all I need to do quite a bit of work, but to get to the point, someone has removed the DECEL Valve. Do I need one for performance or is it an early attempt at emissions control. Should I just plug each one of the vacuum hose nipples leading to the decel valve. Thank you (IMG:style_emoticons/default/chair.gif) You can run without it. Both hoses need to be plugged. You car will drop rpms much faster without it. Same feeling you get from a lighter flywheel. If you are OK with that, run without it ... (IMG:style_emoticons/default/driving.gif) Andy |
motomadness1947 |
Jun 8 2010, 02:48 PM
Thats what I thought, but wanted to make sure. Thanks for the reply
Lo-Fi Version | Time is now: 10th June 2024 - 08:26 AM |
