bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,934 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
Got the tranny back in today, and before tightening up the attaching bolts, the fork moved on the pivot freely. After tightening up the bolts, the fork is about 1/2" out from the case and locked down. (IMG:style_emoticons/default/confused24.gif)
Question: Does the pivot ball go down into the cup on the fork, or just 'float' on the top of the cup. I just held the fork in place over the ball and then tightened up the allen screw/clamp that holds the 2 together. If this is ok, then I'm guessing I let the throwout bearing slip too far forward on the shaft as I mated the tranny to the motor, and missed that when tightening up the screws. Suggestions? Thanks |
Lo-Fi Version | Time is now: 6th July 2025 - 12:02 PM |
