head lights & fog lights 1974 914, need to know what the hell shine the light please |
Tman914 |
Aug 31 2010, 07:54 AM
Member Group: Members Posts: 136 Joined: 9-December 04 From: "Livermore, Ca" Member No.: 3,247 Region Association: Central California |
1. Ok so i trun on the head lights & the fog lights together and then i hit the high beams and the fog lights trun off is this right.
2. And the other deal is i trun on the fog lights by them self and they will not come on until i trun on the head lights is this right too just alittle confuse can any one shine the light Thanks |
dr914@autoatlanta.com |
Aug 31 2010, 08:09 AM
914 Guru Group: Members Posts: 7,896 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
yup set up just like the factory intended!!!
1. Ok so i trun on the head lights & the fog lights together and then i hit the high beams and the fog lights trun off is this right. 2. And the other deal is i trun on the fog lights by them self and they will not come on until i trun on the head lights is this right too just alittle confuse can any one shine the light Thanks |
Aug 31 2010, 08:10 AM
did not want too much light to blind people back then so did not let the driving lights work with the high beams Plus they were actually considered fog lights because of the fluted lens
Spoke |
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
My 71 behaves the same way as when the high beams are on the fogs turn off.
My fogs come on when I go to parking lights or low beams. |
Eric_Shea |
Aug 31 2010, 08:37 AM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
This is a great solution:
http://www.jwesteng.com/porsche/914/fog.htm Signal other drivers easily with a flash of your fog lights using the column lever. Also allows turning on the fog lights when the headlights are off. |
Tman914 |
Aug 31 2010, 09:48 AM
ok thanks guys kinda just like to run the fog lights at times with the parking lights is this possible
underthetire |
Aug 31 2010, 10:07 AM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
This is a great solution: http://www.jwesteng.com/porsche/914/fog.htm Signal other drivers easily with a flash of your fog lights using the column lever. Also allows turning on the fog lights when the headlights are off. (IMG:style_emoticons/default/agree.gif) Since my Pilot driving lights are way better than those crappy Ebay halogens I bought, I use it all the time. |
Tom_T |
Aug 31 2010, 10:44 AM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
zonedoubt |
Aug 31 2010, 11:23 AM
Canadian Member Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada |
This is a great solution: http://www.jwesteng.com/porsche/914/fog.htm Signal other drivers easily with a flash of your fog lights using the column lever. Also allows turning on the fog lights when the headlights are off. (IMG:style_emoticons/default/agree.gif) I set mine up this way. |
Tman914 |
Sep 1 2010, 08:05 PM
just order it thanks guys for all your help
VaccaRabite |
Sep 1 2010, 08:53 PM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Engman is a GREAT seller. Won't go wrong.
But this thread (which is how I have mine set up) would have let you do the same thing for free. I had it wired using the stock wires and one doubler from radio shack in under 15 minutes. http://www.914world.com/bbs2/index.php?showtopic=97889 Zach |
Lo-Fi Version | Time is now: 8th June 2024 - 07:05 PM |
