Headlight pop-up problems, Any suggestions? |
boston914 |
Apr 23 2004, 07:26 AM
Member Group: Members Posts: 52 Joined: 15-July 03 From: Boston, MA Member No.: 912 |
My healights seem to have a mind of their own!
When I turn on the headlights, the pop-up then close repeatedly! I have to play with the knob several times (pushing/pulling) to get them to stay either completely open, or completely closed. Any suggestions on how to fix this problem? Thanks! --------------------------------------------------------------------------------------- '76 Malaga Red just out of winter storage this week! |
Neal |
Apr 23 2004, 09:44 AM
Member Group: Members Posts: 300 Joined: 23-April 03 From: Sammamish, Washington Member No.: 605 |
I think you may have a relay problem, take the black plastic cover off were the relay plugs in and pop it out, clean the pins and replace it. I have one headlight that will refuse to pop up until I wiggle the relay. Worth a try
Neal |
Brad Roberts |
Apr 23 2004, 10:31 AM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Yes. What Neal said. It sounds like you have some weak relays that are not pulling in all the way. Easy fix. Your fuse panel has relays on the back side of it that you can use for testing. You also have relays on the relay board behind the driver in the passenger compartment.
B |
boston914 |
Apr 23 2004, 12:38 PM
Thanks for the help!
Lo-Fi Version | Time is now: 7th June 2024 - 04:41 PM |
