Idled for ten minutes, blipped the throttle a couple times, now nothin, Where would you start? |
skota |
Dec 18 2010, 04:05 PM
Member Group: Members Posts: 95 Joined: 21-October 10 From: madison wi Member No.: 12,291 Region Association: None |
I'm new to 914s so I was hopeing for a little help. Bought the car a couple months ago and it run great until now. I haven't been driving it because I'm in Wisconsin and had some things to work on to get it ready for spring. I've been disconecting the battery and have restarted the car three or four times in the last few months. A couple days ago though, it started fine, I let it idle for about ten minutes, then blipped the throttle a couple times and after returning to idle, quit running.
Where should I start? Thanks, Steve |
skota |
Dec 18 2010, 04:15 PM
I should add, it still turns over fine, it won't fire up at all though.
dr914@autoatlanta.com |
Dec 18 2010, 04:17 PM
914 Guru Group: Members Posts: 7,894 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
TheCabinetmaker |
Dec 18 2010, 04:19 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Not trying to be a smartass, but are you sure it has gas? The gauges can lie.
skota |
Dec 18 2010, 04:26 PM
I should add, it still turns over fine, it won't fire up at all though. what year and is it fuel injected? 1.7 1.8 or 2.0 engine? That would be good info to include, it's a 2.0 with fuel injection, 74 I'll check the gas too, thanks |
76-914 |
Dec 18 2010, 05:00 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,508 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
FP relay?
tomeric914 |
Dec 18 2010, 09:21 PM
One Lap of America in a 914! Group: Members Posts: 1,259 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States |
Ignition distributor loose? Maybe moved out enough to not engage with the distributor drive?
Lennies914 |
Dec 18 2010, 10:27 PM
Slacker Group: Members Posts: 828 Joined: 9-January 10 From: NorCal Member No.: 11,216 Region Association: Northern California |
Do you hear the fuel pump when you first turn the key?
skota |
Dec 20 2010, 04:53 PM
Not trying to be a smartass, but are you sure it has gas? The gauges can lie. that's awesome, it was out of gas. Gauge read an 1/8th of a tank left. Lesson learned. Thanks vsg914 (IMG:style_emoticons/default/beerchug.gif) |
914itis |
Dec 20 2010, 09:35 PM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
Not trying to be a smartass, but are you sure it has gas? The gauges can lie. that's awesome, it was out of gas. Gauge read an 1/8th of a tank left. Lesson learned. Thanks vsg914 (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 11:30 AM |
