timofly |
Member ![]() ![]() Group: Members Posts: 168 Joined: 21-February 09 From: VA Member No.: 10,082 Region Association: MidAtlantic Region ![]() |
Call me crazy, but now that my first 914 is pretty much done, I am contemplating doing another one, maybe a six. With retirement looming, I want to (have to) do more of the work myself. Two questions to the group about tools:
1. what kind of impact wrench would you recommend, and 2. what kind of welder would you recommend? I did some gas welding 30 years ago, and need to relearn a lot, but before buying anything I want to hear what others have used and liked. How about it? Good, bad and ugly experiences? |
scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
You can find used Blue Point impacts pretty cheap and IMHO they are just as good as the Strap-On ones. And much better than a Crapsman or anything else. Second chopice would be a NEW Ingersoll
Welder = Miller 140 all the way. Already set up for gas. Get a spool of .025 wire and go at it. I have done everythign form sheet metal up to 1/4 in a single pass with this machine. There is NO reason for a home hobbyist to buy anything larger |
ScottD914 |
Member ![]() ![]() Group: Members Posts: 69 Joined: 27-December 07 From: New London, CT Member No.: 8,506 ![]() |
Sounds like a great goal and project, one I'd like to take on some day.
I'm just finishing up a '74 914/4 that had tons of rust. The first tool I bought (the day after I bought the car) was a Millermatic 180 mig welder. Very versatile and easy to use. Took a bit-o-practice, but it all came back from 30 years ago. Best of luck! |
rmital |
Northeast optimist ![]() ![]() ![]() Group: Members Posts: 1,954 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 ![]() |
rfuerst911sc |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States ![]() |
In my opinion the impact wrench is only as good as the compressor driving it. You can buy the best impact wrench but if you're driving it with a pancake oiless POS you will not get the results you want. I have an old B&D 1/2 impact that is plenty powerful when driven with my two stage compressor. Look around on Craigslist for your area there are LOTS of tools being sold due to the economy. Nothing wrong with buying used and saving $$$$. The mig welder you really can't go wrong with Miller, Hobart, Century or Lincoln they all make good 110 volt welders. Buying used can save you money here also but make sure it works. Buying a brand you can have serviced locally is a plus just in case you have to. And buy a mig not just a wire feed welder. You know with the gas setup already with it and a bottle of gas if possible. And building a six is a great idea, I recently completed a 3 year build of my GT clone with a 3.0. (IMG:style_emoticons/default/biggrin.gif)
timofly |
Call me crazy, but now that my first 914 is pretty much done.... did you solve your alignment problem...or the car pulling in one direction?? Ray, Sure did, pretty simple matter of adjusting the front torsion bars. Also fixed the idle problem, just in time for the winter snow to set in and TGP is now relegated to the barn for the duration. Tim |
underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
I agree with the good ir guns. Not the home depot ones for thirty bucks. If you have enough money, you cant beat miller, and the 140 as suggested kicks ass. If you can't swing the miller bill, then a holbart handler then Lincoln weld pack. Don't do a harbor freight one, I have one I needed for an emergency, it works but not well.
draganc |
Senior Member ![]() ![]() ![]() Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States ![]() |
I have a Hobart Handler 125 with a gas conversion and it works very well. Don't waste your time using a flux core welder/wire if you don't weld outside - it's a major PIA. In addtion, I have a medium size bottle.
Have fun, Dragan PS: Hobart is made in the USA and has a very good warranty (5/3/1 years). |
WFG |
Newbie ![]() Group: Members Posts: 49 Joined: 6-December 05 From: nashville tenn 37076 Member No.: 5,243 ![]() |
IR guns are not that good any more repair parts are hard to get made in china now
JoeSharp |
In Irvine, Ca. May 15-18 ![]() ![]() ![]() ![]() Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States ![]() |
Hey Tim, I have a bunch of impact drivers but I don't use them. I take every thing apart by hand and reassemble them the same way. I use a torque wrench almost everything during reassembly. I want to know that what was wrong and that it is all correct when I reassemble it.
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
Hey Tim, I have a bunch of impact drivers but I don't use them. I take every thing apart by hand and reassemble them the same way. I use a torque wrench almost everything during reassembly. I want to know that what was wrong and that it is all correct when I reassemble it. If we're talking about actual restoration/assembly/fabrication, I agree. Mostly. Here in the Land Of Salted Roads I've had to use my impact wrenches to loosen fasteners that "shouldn't" have needed it. Nowadays when I do anything with the Titan, I buy all new hardware because even if it's not damaged in the removal, I can't bear to reuse rusty cr&p... Where they really shine is the semi-annual tire swap. Subie has 5-lug wheels, Titan has 6-lug. 1/2" impact gets them _off_painlessly. (They are re-installed by hand, individually, and torqued.) Been a long time since I autocrossed actively but doing 3 swaps a day (street / race / street ) for two days gets old come Sunday night. Wouldn't be a problem now... Probably the only place on a Porsche where the impact wrench is the tool of choice is the rear stub axle nuts - and for removal only, of course. My 1/2" impact is an ancient Rockwell I bought in 1980 and it is finally showing its age. I have been eyeing the titanium-cased extended-shank IR. There is no doubt the Snap-On stuff is a great value for the guys who use them all day long and make a living at it, but for occasional use I think you're paying for durability that you won't actually utilise. Impact tools do like their air, but nothing uses air like rotary tools. My compressor recovers between wheels on lugnut removal, but it's gasping after just a couple of minutes with a die grinder. Must go bigger - again... |
Lo-Fi Version | Time is now: 19th July 2025 - 07:16 AM |
