mrbubblehead |
Twodollardoug ![]() ![]() ![]() Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California ![]() |
im totaly bummed out about this. after about 50 hours of research and electrical work on my new toy, i found this while hooking up my fuel line.
![]() ![]() its really bad. to the point where i dont think its safe to drive the car.... (IMG:style_emoticons/default/headbang.gif) do you guys think this is something i should try fix this myself and box it in? im not sure my fab skills are up to the task.... or should i leave this one up to the professionals? is there a shop in so cal. that is competent enough to fix this? forgive my noobieness for not knowing any shops around. i'm not out to insult anyone. i just dont want a hack job. i could do that myself. LOL |
mrbubblehead |
Tom_T |
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California ![]() ![]() |
Better check the other side too! (IMG:style_emoticons/default/dry.gif)
IMHO - get 1 or 2 new repro consoles from Restoration Design (see member vendors & banner ad) & replace one or both - don't try to patch those up, cuz they'll just continue to rust & fail later. IIRC - AA also sells them in repro form. If not up to your skills, PM to Ed Arango in HB, or to Kevin/kconway in Long Beach about his guy referred to me below - <snip> Message Forwarded From kconway Tom, I received a call from Milt Becker this morning and he said he would be interested in speaking to you about your car and perhaps coming out to take a look. You can reach him at this number: 562-424-5943. Not sure of his schedule but if you leave a message he's sure to get back to you. Good luck, Kev <end snip> I think both guys can bring their eqpt. to your place to do the work, and Ed may be using the same guy. I haven't used either one yet, so ask them for referrals. PS - no, definitely NOT safe to drive that way! |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,185 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
don't be bummed! Happens all of the time. We have two cars in the shop right now that we are installing new ones. We manufacture the piece and sell it to all of the usual suspects, but you will need to drop the engine to install it. If you can weld you can install it. Do not drive the car though!!
im totaly bummed out about this. after about 50 hours of research and electrical work on my new toy, i found this while hooking up my fuel line. ![]() ![]() its really bad. to the point where i dont think its safe to drive the car.... (IMG:style_emoticons/default/headbang.gif) do you guys think this is something i should try fix this myself and box it in? im not sure my fab skills are up to the task.... or should i leave this one up to the professionals? is there a shop in so cal. that is competent enough to fix this? forgive my noobieness for not knowing any shops around. i'm not out to insult anyone. i just dont want a hack job. i could do that myself. LOL |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,234 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
its really bad. to the point where i dont think its safe to drive the car.... (IMG:style_emoticons/default/headbang.gif) do you guys think this is something i should try fix this myself and box it in? im not sure my fab skills are up to the task.... or should i leave this one up to the professionals? is there a shop in so cal. that is competent enough to fix this? forgive my noobieness for not knowing any shops around. i'm not out to insult anyone. i just dont want a hack job. i could do that myself. LOL Not safe to drive! The good news is, this is a pretty common failure. Restoration Design makes a complete replacement piece: http://www.restoration-design.com/ The bad news is, this is NOT a newbie job. You'll need someone experienced to fix this correctly. The Slow-Cal guys should be able to point you to a good shop ... (IMG:style_emoticons/default/welder.gif) |
mrbubblehead |
its really bad. to the point where i dont think its safe to drive the car.... (IMG:style_emoticons/default/headbang.gif) do you guys think this is something i should try fix this myself and box it in? im not sure my fab skills are up to the task.... or should i leave this one up to the professionals? is there a shop in so cal. that is competent enough to fix this? forgive my noobieness for not knowing any shops around. i'm not out to insult anyone. i just dont want a hack job. i could do that myself. LOL Not safe to drive! The good news is, this is a pretty common failure. Restoration Design makes a complete replacement piece: http://www.restoration-design.com/ The bad news is, this is NOT a newbie job. You'll need someone experienced to fix this correctly. The Slow-Cal guys should be able to point you to a good shop ... (IMG:style_emoticons/default/welder.gif) well i do have a mig welder, and a tig welder. and more time than money. my fear is not getting the alignment of the pivot correct. is ther a jig out there to use? i have converted swing arm vw's to irs in the past. my confidence level is going up. im going to have to fix it myself. im already starting on taking the engine out. is there a thread or tutorial on the repair? i have searched but really havnt found anything. |
JoeSharp |
In Irvine, Ca. May 15-18 ![]() ![]() ![]() ![]() Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States ![]() |
We have a friend in your neighborhood that can help you. He doesn't post here and I believe he lives in Yucaipa. PM me your phone number and I'll try to get you 2 together.
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
That looks very familiar:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1290372313.1.jpg) http://www.914world.com/bbs2/index.php?sho...113186&st=0 I just finished fixing mine, but it was the drivers side. I assume your is the passenger side. The passenger side can be purchased new, but not the DS. I welded the crack with a backup strip, then put the reinforcement plates from tangerine racing on BOTH sides. THEN.... I will be putting the support in that braces the ears to the firewall. Stu |
mrbubblehead |
wow, im not the only one with this problem. im going to check out your thread know. thank you. i googled 914 suspension console repair and got a bunch of hits. i helps to use the correct terminology.
SirAndy |
wow, im not the only one with this problem. im going to check out your thread know. thank you. i googled 914 suspension console repair and got a bunch of hits. i helps to use the correct terminology. I used our search and typed in: +suspension +console and got hours worth of reading ... (IMG:style_emoticons/default/smile.gif) |
sean_v8_914 |
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 ![]() |
I have posted at least 3 of these repairs here and on club. the factory manual has teh measuring points explained in detail. I use 1/8 stainless wires cut to facory spec and measure as illustrated in teh manual. I have secrets to share but cant post them here..."they" are watching us"
I have done more than I remember now. please do not patch it. they are ALL rotten inside Attached image(s) ![]() |
sean_v8_914 |
the driver side is not available and must be fabricated but it rarely fails. the battery above teh right side is teh main cause
sean_v8_914 |
bvmncgh
sean_v8_914 |
mn,
sean_v8_914 |
whoever welds it up: be sure they passivate the rust before welding it up
mrbubblehead |
thanks alot sean. a picture is worth 1000 words.
mrbubblehead |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
Looks great! nice welds! (IMG:style_emoticons/default/first.gif)
silver74insocal |
Senior Member ![]() ![]() ![]() Group: Members Posts: 736 Joined: 26-November 09 From: rancho cucamonga Member No.: 11,073 Region Association: Southern California ![]() |
(IMG:style_emoticons/default/smilie_pokal.gif) looks pretty damned good to me..keep it up...
championgt1 |
Don't embarrass me Filmore! ![]() ![]() ![]() ![]() Group: Members Posts: 2,681 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest ![]() |
Lo-Fi Version | Time is now: 2nd July 2025 - 08:23 PM |
