| flipb |
Jan 5 2011, 08:36 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,870 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region
Picked up my '74 2.0 this evening after getting a new set of EMPI 40mm's in place of the Weber Progressive that was on there when I bought the car last year.
Wow. It's like a different car. I was expecting a little better throttle response and less gurgling/flooding, but here's what I found: No gurgling or stumbling at all... big difference there. Instantaneous throttle response Quicker throttle take-up - I think the cable has less play than before. This is the biggest change and one I'll have to adjust to... I found myself revving to 3K RPM to get rolling in 1st gear. Got to get used to a softer touch. Smoother running at idle and throughout the rev band Big difference in sound.... this one I wasn't expecting. With the single Weber, there was a lot of burping, popping, etc, sounded pretty mean. Now it's got a deeper, throatier, smoother howl. Didn't touch the exhaust, but I swear there's a big difference in the sound. Can also hear the carbs sucking air at times. All of this is more impressive since I was driving home in 30-something degrees. The Weber carb had major issues with cold temps, due to fuel condensing in the intake runners. My mechanic also changed the trans fluid. So far I've only driven it ~10 miles on a scenic drive home from the shop. Hope I get another drive this week, although they're predicting snow... which means heavily salted roads. (IMG:style_emoticons/default/sad.gif) Oh, and here's my "ask": My mechanic had a very hard time getting the carbs dialed in. It's running rich right now, but he said the engine doesn't seem to like when he leans it out. Can others please share tuning/setup/jet sizing/etc. tips for my setup? It's new EMPI 40mm carbs on a stock 2.0 motor, for street use. Much obliged, and happy (IMG:style_emoticons/default/driving.gif) |
| JoeSharp |
Jan 6 2011, 03:51 AM
In Irvine, Ca. May 15-18 ![]() ![]() ![]() ![]() Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
The cars like to run a little rich, helps to keep them cool. Do you read plugs? You may want to go to the next hotter plug.
| Gint |
Jan 6 2011, 05:50 AM
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,106 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
(IMG:style_emoticons/default/agree.gif) My dual Weber 2056 runs a little fat and it likes it that way.
I edited your title BTW. (IMG:style_emoticons/default/wink.gif) |
| BarberDave |
Jan 6 2011, 06:34 AM
Barberdave ![]() ![]() ![]() Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
You will love it , I felt mine was dangerous with the singel Carb. When your in a safe place to due this , Peddle to The Metal, Sweet music. Dave (IMG:style_emoticons/default/slap.gif) P.S. If you don.t have them allready get some ," Rain Hats " |
| flipb |
Jan 6 2011, 07:47 AM
| flipb |
Jan 6 2011, 07:51 AM
After bringing her home last night, I figured she ran so well in the cold (and with snow predicted Friday, didn't want to miss a chance) that I'd drive her to work today.
But when I walked up to the car, I noticed a small puddle. Under the FRONT. Brake fluid. (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif) It's a slow drip that probably started on my way home last night.. I had to make one quick/sudden stop. Appears to be coming from the vicinity of the Master Cylinder, dripping from the dirt shield below there. Didn't drive it to work... but here's a question: If I top off the brake reservoir, is it safe to bring it the ~3 miles to my mechanic's shop? I'm afraid how much more fluid will have leaked by the time I get home from work today... |
| VaccaRabite |
Jan 6 2011, 08:24 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,840 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
If I top off the brake reservoir, is it safe to bring it the ~3 miles to my mechanic's shop? I'm afraid how much more fluid will have leaked by the time I get home from work today... Don't sweat it. Totally safe so long as you never need to stop. (IMG:style_emoticons/default/bootyshake.gif) Play it safe and get it towed, or jack it up and remove the cover and fix it in your garage. Replacing a master is not hard to do, but it does take some time, especially to bleed it all firm again. As to jetting, I don't know where the stock EMPI 40s start. Do you know if you are fat at idle, or at revs. Zach |
| Woody |
Jan 6 2011, 08:57 AM
Sandbox Rabblerouser and head toilet scrubber ![]() ![]() ![]() ![]() Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
The fuel enrichment valves have a tendency to stick open on those empis and go full rich. I jb welded them shut.
| sean_v8_914 |
Jan 6 2011, 09:13 AM
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
what is a "fuel enrichment valve"?
how low was the resevoir? I would not gamble with brake issues any chiltons book at FLAPS has a spark plug reading guide in it. slightly rich is OK but if it lays alot of black soot in the tail pipe, that's too rich and will dirty up the oil quickly single center mount weber is a good carb only if your low on dough and you need it to kinda run ok to get you places in warm weather above 3000rpm intake sound (carbs) are a large portion of the total engine sound. modern cars have big air boxes designed to reduce this. rain hats will reduce it and change the tone. Porshce six music is enhanced by it. we useed to flip the air cleaner lid on our muscle cars to make it louder |
| sean_v8_914 |
Jan 6 2011, 09:14 AM
ps. winter tuning may be too rich in teh summer
| yeahmag |
Jan 6 2011, 12:00 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,479 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California
Damn... Just got back from Fairfax Station, VA. I spent two weeks there driving around; DC, MD, VA. Didn't see a single 914! Glad you are there to represent.
| flipb |
Jan 6 2011, 12:11 PM
Damn... Just got back from Fairfax Station, VA. I spent two weeks there driving around; DC, MD, VA. Didn't see a single 914! Glad you are there to represent. There aren't many on the roads around here. I know of maybe half a dozen in northern Virginia (mostly members here). If I may hijack my own thread... My 914 has a 19mm master cylinder, installed by the previous owner. Assuming my new brake leak is going to require a new MC, do I keep with the 19 or take it back to the stock 17mm? I've seen other threads debating/debunking the advantage of a 19mm MC - whether it actually improves braking or just changes the pedal feel. Would it be more work to switch back to 17mm? (e.g. would the 19mm MC use different brake lines or any other modifications that I'd have to undo?) |
| yeahmag |
Jan 6 2011, 12:12 PM
No other mods needed... If the car felt "hard to stop" I'd go to a 17mm. I run a 17mm on my autocross car for modulation purposes. More travel, but more 'resolution' at the pedal.
| VaccaRabite |
Jan 6 2011, 12:37 PM
Its possible that the PO put one of the el-cheapo URO masters on it. I bought one a few years ago, and it started leaking from the top a few months later. Then I bought the real MC and its been great.
You can buy the real one in 19mm for a lot cheaper then the real 17mm. Zach |
| VaccaRabite |
Jan 6 2011, 12:38 PM
It could also be somehting as easy as a split boot where the hose from the filler goes into the cylinder. its worth putting the car in the air and looking.
Zach |
| flipb |
Jan 6 2011, 12:44 PM
It could also be somehting as easy as a split boot where the hose from the filler goes into the cylinder. its worth putting the car in the air and looking. Zach Thanks. From the look of things before I left my house this morning, there were several ounces of fluid on the ground already... and the reservoir wasn't empty, so I'm afraid it's leaking out of the lines. Come to think of it, my method of getting the car off the ground is to roll two wheels onto ramps - I don't have a floor jack. I wouldn't dare attempt to drive it up onto ramps without knowing if the brakes will stop it when I get to the top... (IMG:style_emoticons/default/yikes.gif) So chances are good that it will sit til I can get it towed. (IMG:style_emoticons/default/sad2.gif) |
| VaccaRabite |
Jan 6 2011, 01:50 PM
From the look of things before I left my house this morning, there were several ounces of fluid on the ground already... and the reservoir wasn't empty, so I'm afraid it's leaking out of the lines. Holy crap! Several ounces?! Are you SURE its not fuel? I would think that several ounces would deplete the reservoir. Both the fuel drain and master cylinder are in covered by the skid plate. Zach |
| underthetire |
Jan 6 2011, 01:56 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
With that much I would expect no pedal left. |
| flipb |
Jan 6 2011, 01:58 PM
From the look of things before I left my house this morning, there were several ounces of fluid on the ground already... and the reservoir wasn't empty, so I'm afraid it's leaking out of the lines. Holy crap! Several ounces?! Are you SURE its not fuel? I would think that several ounces would deplete the reservoir. Both the fuel drain and master cylinder are in covered by the skid plate. Zach Yeah, fuel was my first thought too. But it was too thick/viscous and didn't smell of gasoline. And although I was rushing to get to work and didn't pull off the dust cover, the drip was coming from right below the MC. I even opened the brake fluid reservoir to smell it and see if it was a "match" for the stuff dripping onto the ground... seemed pretty close. I'd compare it to vegetable oil for viscosity. |
| zymurgist |
Jan 6 2011, 03:06 PM
"Ace" Mechanic ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
Lo-Fi Version | Time is now: 9th March 2026 - 07:51 PM |
