Are All D-jets Created Equally?, Changing from carbs back to FI... |
knuckledrgr914 |
Jan 30 2011, 04:51 PM
Newbie Group: Members Posts: 46 Joined: 17-June 08 From: Meridian Member No.: 9,180 Region Association: None |
I have a '70 914, 1.7L, 96mm, larger cam (last time I searched for #'s on the cam it came back as a replacement for a 2.0). My current state is the PO converted the motor to carbs, left the carbs off while sitting outside and water got into the motor (sat there for years this way). I purchased the car ~ 3 years ago, cracked the case and found the water and rust did not get all the way inside. Purchased a rebuild kit (gaskets and bearings), new 96mm pistons, cylinders, rings to replace the seized/rusted ones, and there it sits. I would like to get it on the road someday, but $$$ is tight (imagine that (IMG:style_emoticons/default/headbang.gif) ).
My questions are... 1. Can I use any D-jet setup for my motor as described above (1.7, 1.8, ...)? 2. What parts will I need, and approximately how much will it cost, to convert to FI? 3. How difficult is it to convert from carbs back to FI (I have little to no experience working on 914's...)? 4. What are some gotcha's I will run into? I am also open to keeping a carb setup, but currently I have to go the least expensive route and the least amount of time having to fiddle with adjustments once it is running. Later on I have bigger dreams, but right now I have to be realistic and I would like to start driving it before another 3 years has passed... Thanks for your time! |
Cap'n Krusty |
Jan 30 2011, 05:11 PM
The cams for 1.7 and 2.0 are the same. Best place to look for a number is the end of the camshaft, visible with the oil pump removed. If there are numbers stamped there, it's an aftermarket grind. D-jet, for all practical purposes, likes ONLY the stock grind. Jake Raby sells a proprietary grind that works, but all the others are an adventure in frustration.
It costs what it costs to buy all the working FI stuff. You find it and you pay whatever the seller wants. The MPS is gonna be expensive, and they're often bad. The throttle switch can be an issue. There are particular combinations of parts that work best together. You're gonna need either larger injectors to feed the increase in displacement, or some way of fattening up the mixture. Search for PB Anders' name and a link to his website. He has all the component information you'll ever need for D-jet. The Cap'n |
stugray |
Jan 30 2011, 05:19 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I am going from D-jet to carbs.
I have at least three complete FI systems including MPS. Stu |
Lo-Fi Version | Time is now: 2nd June 2024 - 10:26 AM |
