SS HE's vs steel HE's, which tranfers/scavanges heat better |
toon1 |
Mar 1 2011, 01:08 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
A friend of mine asked me which set of HE's would transfer heat away from the engine better.
I would think it would be the SS HE's due to the fact there is less mass to retain the heat. Since I don't know, and it seemed like an interesting question,I thought I would throw up the question to the world. |
URY914 |
Mar 1 2011, 01:15 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,883 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I don't think there is much difference between NEW steel and ss. The difference comes when the steel ones rust away.
And BTW the HE's don't "tranfer heat away from the engine". Air transfers the heat away from the engine. |
jimkelly |
Mar 1 2011, 02:07 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
he is asking - WICK - away.
i would bet one would wick away hat better than the other?? though the difference may be negligable?? because SS has wider ID than steel 1.7 and 1.8 type - i would assume SS would be better - thought steel 2.0 and SS 2.0 have about the same ID if i remember correctly. sorry - what was the question (IMG:style_emoticons/default/biggrin.gif) |
Tom_T |
Mar 1 2011, 02:16 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Very little or no difference, unless rusted - which then breaks the air flow from the fan, through the heater boxes/HEs & either vented out the heater flapper boxes (cabin heat off mode) or into the cabin with the heat on - or a combination depending on the setting of the floor lever between bottom/closed & top/open full position.
Of course that assumes the heating system is all hooked-up, complete & operable. The major cooling on 914s, VWs, etc. is both Air & Oil cooled, so those systems are more important to be in place properly, complete & fully functional - including the engine tins to direct the impeller fans' airflow. The primary reason to go to the SS HEs is no rust to speak of - at least not in our lifetimes! (IMG:style_emoticons/default/biggrin.gif) IIRC Porsche itself eventually switched to SS on the air/oil-cooled 911/930/993 HEs. |
Lo-Fi Version | Time is now: 29th May 2024 - 04:36 AM |
