WTB: Breather Box, sick of oil film all over engine! |
wertygrog |
Mar 25 2011, 01:27 AM
wertygrog Group: Members Posts: 428 Joined: 12-November 05 From: Long Beach, CA Member No.: 5,114 Region Association: Southern California |
Hi, my 914 (40IDF's) has some major commuting duty coming up and I want to address the breather situation. I have the el cheapo $20 breather box with the foam in it, but it doesn't work well for my old worn engine. I need one of the better breather boxes, used is fine. Let me know what you have! (IMG:style_emoticons/default/beerchug.gif)
BarberDave |
Mar 25 2011, 06:26 AM
Barberdave Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
Brent: When I installed a breather box ( the kind with foam in the box) it didn't work well untill I drilled the guts out of the PCV valve. Makes it a clear shot. Also sounds like you have a lot of blow by, beather won't cure that , but keeps the oil off the of the engine. Good Luck Dave (IMG:style_emoticons/default/slap.gif) |
euro911 |
Mar 25 2011, 09:42 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
I made a breather 'spit bottle' from a thick plastic beverage bottle. It's mounted it under the trunk adjacent to the starter.
It's filled it with a big wad of spun cotton to keep oil from sloshing around. It doesn't look pretty, but it works well and it didn't cost much (IMG:style_emoticons/default/idea.gif) Attached image(s) |
Lo-Fi Version | Time is now: 6th June 2024 - 07:23 AM |
