Fuel Pressure Gauge, Inexpensive solution |
Bartlett 914 |
Mar 27 2011, 02:15 PM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
There is a sale on pressure gauges at MSC. This is a glycerin filled gauge zero to sixty LBS. I use something similar in my car. You will need to make up fittings and some hose but at 20 bucks, this makes for a nice addition to the engine compartment. I leave mine in all the time. It is nice to look and see that you have fuel pressure at a glance. I had a relay board problem once. I could immediately see the problem was fuel. This saved a lit of time in trouble shooting.
60 lbs pressure gauge |
jim_hoyland |
Mar 27 2011, 02:54 PM
Get that VIN ? Group: Members Posts: 9,318 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
There is a sale on pressure gauges at MSC. This is a glycerin filled gauge zero to sixty LBS. I use something similar in my car. You will need to make up fittings and some hose but at 20 bucks, this makes for a nice addition to the engine compartment. I leave mine in all the time. It is nice to look and see that you have fuel pressure at a glance. I had a relay board problem once. I could immediately see the problem was fuel. This saved a lit of time in trouble shooting. 60 lbs pressure gauge (IMG:style_emoticons/default/agree.gif) I've relied on the fuel pressure gauge when ever there is a sudden shut down. If my fuel system is not the problem, pressure gauze still reads running pressure. Mounted mine next to cold-start where it's easy to see soon as lid is opened. |
76-914 |
Mar 27 2011, 04:18 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,508 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
There is a sale on pressure gauges at MSC. This is a glycerin filled gauge zero to sixty LBS. I use something similar in my car. You will need to make up fittings and some hose but at 20 bucks, this makes for a nice addition to the engine compartment. I leave mine in all the time. It is nice to look and see that you have fuel pressure at a glance. I had a relay board problem once. I could immediately see the problem was fuel. This saved a lit of time in trouble shooting. 60 lbs pressure gauge (IMG:style_emoticons/default/agree.gif) Same thing. Car died, saw the fuel gage @ 15psi and knew immediatly. I put the gage in the clock opening. |
Lo-Fi Version | Time is now: 7th June 2024 - 03:07 PM |
