ezbngreen914 |
Member ![]() ![]() Group: Members Posts: 441 Joined: 11-December 10 From: Sautee, GA Member No.: 12,472 Region Association: South East States ![]() |
I think I almost have this thing back on the road, but noticed something when I was working on the fuel lines. I noticed that the hose between the Cylinder head and the Flashback valve on the passangers side is missing.
What is the purpose of this hose/system? Its been missing the whole time Ive owned it (10 months). Is it safe to take it for a short test drive without it? Man, I'm Jonesing for some seat time but I don't want to mess anything up. (IMG:style_emoticons/default/driving.gif) |
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
I think it's basically a vent for the crankcase as the vapor from the crankcase vents through the pushrod tubes, then through the tube in the head, is combined with the same tube from the other head at the anti-flashback valve and from the valve to the air cleaner for the vapors to be burned in combustion. If you don't have a hose connected to the head vent, you risk oil spray in the engine compartment.
914Mels |
Member ![]() ![]() Group: Members Posts: 357 Joined: 20-June 11 From: Santee Member No.: 13,221 Region Association: Southern California ![]() |
Can you take a picture of the engine showing whats missing?
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Type 47 has the correct answer. One hose from each head (rocker box) to the Anti Flash Back valve and then a hose to the air cleaner. Crankcase breather & emissions control. Valve only prevents a backfire flame from entering the crankcase for prevention of a fire or explosion.
If you don't hook the hose up, you will have oil all over one side of the engine. If you plug it, you take the chance of blowing seals on the engine (flywheel, front seal, push rod tube seals) |
Derek Seymour |
Member ![]() ![]() Group: Members Posts: 394 Joined: 10-March 09 From: Yucaipa Member No.: 10,151 Region Association: Southern California ![]() |
Type 47 has the correct answer. One hose from each head (rocker box) to the Anti Flash Back valve and then a hose to the air cleaner. Crankcase breather & emissions control. Valve only prevents a backfire flame from entering the crankcase for prevention of a fire or explosion. If you don't hook the hose up, you will have oil all over one side of the engine. If you plug it, you take the chance of blowing seals on the engine (flywheel, front seal, push rod tube seals) these two show it http://www.bowlsby.net/914/Classic/zTN_FI_..._Late1974_A.jpg http://www.bowlsby.net/914/Classic/zTN_FI_...3-Early1974.jpg |
ezbngreen914 |
Thanks for the info everyone! 914 world to the rescue once again. I think I'll go to the auto parts store and get some hose tomorrow. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 17th June 2024 - 11:38 AM |
