How to use Copper Coat for head sealing, Simple, possibly stupid question |
tornik550 |
Sep 2 2011, 07:58 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
It make be very obvious however I just want to be absolutely sure before I proceed.
I have read a few threads where some people use Permatex Copper Coat to assist in head sealing. Do you just spray the whole combustion chamber? Do you mask the sealing surface off or just spray everything? (I could only find a spray version, is there another type?) |
Dr Evil |
Sep 2 2011, 08:19 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Permatex with the indian head on it is what I have used. Whether or not is another argument. The bottle has a brush in it. If you are using head gaskets (please dont) then you would apply it to those as it is gasket dressing rather than sealant. For the barrels to the heads, I am not sure.
HAM Inc |
Sep 2 2011, 08:32 PM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
I use the aerosol. I just spray a good coating all over the sealing surfaces. Don't worry about getting it on the valves, it won't hurt a thing. I let it set up before installing the heads.
Dr Evil |
Sep 2 2011, 08:46 PM
There you go, the expert himself (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 5th June 2024 - 10:16 AM |
