bernbomb914 |
one of the oldest Farts on this board ![]() ![]() ![]() Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 ![]() ![]() |
anyone build a engine stand to test how a new engine runs before installing it or running it in a bit before installing it? Are there plans or blueprints avalible?
Bernie |
sj914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 805 Joined: 20-August 03 From: San Jose, CA Member No.: 1,053 ![]() |
I don't know about a test stand, but I do recall seeing an mpeg that I think Britain posted that showed him starting an engine sitting on a pallet. I think if you mount the engine crossbar it'll be enough to keep the engine from rolling around from the torque.
ps I've done test starts on an old picnic table in my backyard before and works pretty well. |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
You can just put on the trans, support the bar ends on jack stands, block up the back of the trans and run it on the floor.
The engine will not roll over from torque. Or you can make a stand using an old trans bell housing... or spend the coin and make a proper adaptor plate and stand. |
michelko |
Senior Member ![]() ![]() ![]() Group: Members Posts: 867 Joined: 30-November 03 From: Germany, Lambsheim Member No.: 1,404 Region Association: None ![]() |
Hi everybody,
this is my high quality (IMG:style_emoticons/default/biggrin.gif) self made engine stand. Not ready yet, but i hope the engine runs the next two or three weeks. :gerflag Attached image(s) ![]() |
michelko |
nother one
michelko |
#3
ruddyboys |
Hummel eigentümer ![]() ![]() ![]() Group: Members Posts: 595 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States ![]() |
This looks great, but what about hook-ups. Battery + to starter, Trans ground to ground, what else
Mark Henry |
Michelco, your stand looks good, but I would just use the stock front mount bar. You will have to remove your fan housing, etc. to get that mount back off.
Yep, you will need to connect a battery, fuel pump, tach, oil pressure warn light, power to the coil and FI, etc...Just like it was in the car. |
lmcchesney |
Member ![]() ![]() Group: Members Posts: 488 Joined: 24-November 03 From: Ocala, Fl. Member No.: 1,381 Region Association: None ![]() |
The comparison is which is more difficult:
Building and adjusting the engine stand vs removing the engine from the engne bay. I agree, working on the engine in the stand would be easier, but other than seeking an oil leak, what else is easier? IMHO (IMG:style_emoticons/default/biggrin.gif) L. McC |
michelko |
Hello,
unfortunately i don´t own a secon engine bar. The wooden bar in the picture has to be cut out to mount the blowerhousing. I fixed that last weekend. Removing the bar is no problem, you can unlock the screw from the underside witout removing the blower. The electric is ready (in my brain) (IMG:style_emoticons/default/biggrin.gif) this should be no problem. Will post pics of it whenn ready in the real world. Regards from Germany (IMG:style_emoticons/default/smilie_flagge6.gif) |
bernbomb914 |
I would think it would be much eaiser to run the engine on the engine stand to set the timing, check for oil leaks, valve adjustment and do all the small checks that are hard to do when it is installed in the car. still looking for some plans
Bernie |
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
I agree it should be lots easier to test run a motor on a stand. I hate tweekng things and setting timing while standing on my head or leaning over the fender trunk lid or crawling underneath to check for leaks and checking valves again.
Plus I should be able to piss the nieghbors off running it in the back yard under the porch cover. Near the beer reefer. (IMG:style_emoticons/default/driving-girl.gif) |
echocanyons |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,109 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California ![]() ![]() ![]() |
Aircooled.net has an engine start kit but I am not sure if our starters will fit the mount.
This seems like an easy route unless you have a spare trans you can chop up...that is if you dont want to run the engine with the whole trans out of the car aircooled's engine start kit |
Mark Henry |
QUOTE(echocanyons @ Jul 18 2004, 06:00 PM) I am not sure if our starters will fit the mount. Our starters will fit but the offset is wrong, it will sit too far in. You might be able to make spacers to correct this. An old trans would be the simplest route to make a stand, you can gut the trans or just cut off the bellhousing. |
michelko |
Hi Guys,
worked a little on the engine stand yesterday. Did the whole wiring for ignition, oil pressure switch, connection for the brain, etc. Took me 4 hours to do it. Works fine, no problems. Engine cranked at first try. Have to buy more fuelline (IMG:style_emoticons/default/smilie_flagge6.gif) Attached image(s) ![]() |
michelko |
#2
michelko |
#3
michelko |
(IMG:style_emoticons/default/wink.gif) #3 should ad a pic
michelko |
#4
wilchek |
Senior Member ![]() ![]() ![]() Group: Members Posts: 506 Joined: 8-June 04 From: Eastern Pennsylvania Member No.: 2,177 ![]() |
Did you use a relay board. If not, what is the best way to wire the motor to run. What are the necessary connections. Your framing looks nice and stable. I was thinking about building one out of metal, but I think I may have changed my mind.
Lo-Fi Version | Time is now: 1st September 2025 - 03:05 AM |
