78mm or 74mm crank recommendation |
Valy |
Sep 28 2011, 11:43 AM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Can anyone recommend a specific crank for a 78mm or 74mm stroke? I'm looking for users that have actually experienced assembling one or the other.
So far I've see that SCAT ,DPR have a nice offerings (I think Jake resells the later one). Also I would, what should I expect in terms of clearance with the case and camshaft? Should I get a reduced cycle camshaft? Thanks |
Matt Romanowski |
Sep 28 2011, 12:39 PM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
I've used a couple of DPR 78mm cranks. Cracked one. Quality is pretty good, but you still need to have the balance checked and measure everything. It's not easy to get one that is perfect.
I've used a reduced base circle cam. Most of the clearancing is on the case and rods. |
Valy |
Sep 29 2011, 01:56 PM
Thanks Matt!
I can't believe this is the only opinion I can get on this forum. Nobody else built a stroked engine over here by himself? (IMG:style_emoticons/default/confused24.gif) Come on, spread some wisdom in here! |
Lo-Fi Version | Time is now: 9th June 2024 - 06:37 AM |
