Boxster rims, What size spacer and studs for rear |
736conver |
Jul 22 2004, 03:02 PM
Advanced Member Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None |
Ok I finally got some tires for my boxster rims. I knew they would need some spacers in the back. My question is does anybody know the size and the length of stud to go in the hub.
Attached image(s) |
736conver |
Jul 22 2004, 03:03 PM
Here's the front. I think I will polish the rims down the road.
Attached image(s) |
ArtechnikA |
Jul 22 2004, 03:08 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
QUOTE(736conver @ Jul 22 2004, 01:02 PM) ...does anybody know the size and the length of stud to go in the hub. you need AT LEAST 1x the diameter (14mm) thread engagement - 1.5x is better. get studs long enough to achieve that. the longest studs i've seen generally available are 100mm (4"). if you need more than 4" of stud for your spacers, you'll need to come up with an alternate plan ... long studs are a standard replacement part - all The Usual Suspects have them. shop around - the prices seem to vary wildly based on nothing i have ever determined ... |
Lo-Fi Version | Time is now: 14th June 2024 - 08:20 AM |
