> just what I had in mind, blower grille, not pasta strainer
machina
post Jul 30 2004, 09:05 AM
Didn't even know this thing existed til jake told me about it. OEM part for vanagon blower housing. Keeps bigger stuff out of your fan and therefore off the cooling fins of your cylinders.
Bolts right on (IMG:style_emoticons/default/clap56.gif)
I was going to fabricate one but now don't have to.
dr
Jeroen
post Jul 30 2004, 09:12 AM
Region Association: Europe
Ok, so stop teasing and spill yer guts...
Where did you find it? Others might be interested too
cheers,
Jeroen
rhodyguy
post Jul 30 2004, 09:18 AM
i've seen a lot of t-4 bus' with those. i felt they would be redundant on a 914, how much lose crap do you have in your engine compartment?. good for a rear orientated engine with the fan facing you. your tie could get sucked in. it would be a pain to remove in a 914 when you wanted to check the belt tension.
kevin
machina
post Jul 30 2004, 09:19 AM
Well I'm one of the few of the misguided who is not running any sealing tin on my motor, that's why I was more concerned about stuff getting in the fan from under the car.
Found it at The Bus Depot online for $8.
busdepot.com, part# 021-119-207.
machina
post Jul 30 2004, 09:20 AM
QUOTE(rhodyguy @ Jul 30 2004, 11:18 AM)
I don't run an alternator, so no belt.
dr
rhodyguy
post Jul 30 2004, 09:29 AM
no tin, no alt, then install one promptly. (IMG:style_emoticons/default/biggrin.gif)
kevin
- Lo-Fi Version Time is now: 14th March 2026 - 12:52 AM
