SOT - recommendations for a reliable low profile floor jack, GRRRRR. POS Craftsman is leaking again |
GaroldShaffer |
Nov 25 2011, 10:46 AM
You bought another 914? Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
A few years ago I bought a craftmans 50240 aluminum low profile floor jack. Since my car is lowered (among other things) for Axing so I wanted something I could take with me to the events that would be able to lift the car at the donuts.
After 6 months the damn thing started leaking fluid. I was able to fix it by replacing the leaking O-ring. It seems every 4-6 months I need to replace this #$!@$#!!! O-ring. (IMG:style_emoticons/default/headbang.gif) I have had enough, every time I want to use it it leaks and now one of the caster wheels has cracked and doesn't roll. I am not going to fix this POS anymore. (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/chair.gif) When I make my next run to the scrap yard it's going to meet its final destiny. (IMG:style_emoticons/default/smash.gif) I do have a nice heavy duty floor jack I can use for my other vehicals, but it doesn't go low enought to fit under the 914. So.................. Any recommendations on a good quality low profile floor jack? It would be nice if it was somewhat lite weight so I don't have to break back trying to lift in my truck. Thanks (IMG:style_emoticons/default/beer.gif) |
Sawfish |
Nov 25 2011, 10:50 AM
Newbie Group: Members Posts: 43 Joined: 28-January 09 From: San Diego Member No.: 9,990 Region Association: Southwest Region |
Sears should replace it for free, if not the aluminum jacks from harbor freight are a good inexpensive alternative
malaga_red75 |
Nov 25 2011, 10:54 AM
'74 2.5L N/A Subie Group: Members Posts: 454 Joined: 5-March 06 From: Menlo Park, CA Member No.: 5,674 Region Association: None |
Sears should replace it for free, if not the aluminum jacks from harbor freight are a good inexpensive alternative (IMG:style_emoticons/default/agree.gif) Sears will replace any tool, no matter how old, no questions asked... I broke a 1/2" socket drive using a cheater bar and they replaced it no problem. -Peter |
GaroldShaffer |
rick 918-S |
Nov 25 2011, 11:02 AM
Hey nice rack! -Celette Group: Members Posts: 20,493 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I just bought a low profile jack from HF. 100.00. It's a rapid pump jack. It goes from 2 5/8 to 20" high. Most don't lift that high.
Mike Bellis |
Nov 25 2011, 11:10 AM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I have the HF low pro aluminum jack. Works great, never a problem.
underthetire |
Nov 25 2011, 11:17 AM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
We had a safety flier at work about aluminum jacks. They were a name brand one, and while lifting a car in our service shop, the thing cracked in half. Damaged the car, and scared the crap out of the mechanic. (we have on site a maintenance shop).
TheCabinetmaker |
Nov 25 2011, 11:33 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I've had one of the HF aluminum rapid pumps for 6 years. Works great, no leaks, light weight. As with any jack, its for jacking only. Always use jackstands.
underthetire |
Nov 25 2011, 11:56 AM
You do know you can buy the replacement warranty at hf as well. If it craps out for any reason, bring it back and they hand you a new one. Would still be cheaper than a name brand one, that is still made in china anyway.
Spoke |
Nov 25 2011, 01:12 PM
Jerry Group: Members Posts: 6,992 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
If it's Craftsman, Sears should replace it. I took a shovel back to them after about 15 years when the spade cracked. No sales receipt, no problem. The guy picked one off of the shelf, I signed a receipt and out I walked.
zonedoubt |
Nov 25 2011, 01:54 PM
Canadian Member Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada |
It must be different for each store. I went into a Sears with a broken socket driver and they clerk said they can't replace it unless it has a serial number stamped on the tool.
Tom_T |
Nov 25 2011, 02:27 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
This isn't lightweight, but is lifts from 2.5" to almost 24" hi - best range I've found, made by Pittsburgh Automotive & sold at HF & maybe elsewhere....
http://www.harborfreight.com/automotive-mo...jack-68050.html |
scotty b |
Nov 25 2011, 02:37 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
NAPA has a STEEL low profile for 300.00 IIRC I believe it is rated at 3 or 4000 Probably one of my next purchases as I am getting too many cars in that I can't get my " standard " jack under without removing the plate first
Cairo94507 |
Nov 25 2011, 02:56 PM
Michael Group: Members Posts: 9,826 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
I have 3 of those lightweight Sears Craftsman floor jacks - all 3 now leak and are about 3 years old. Two weeks ago Sears said they only warranty hand tools for life, not jacks.
PanelBilly |
Nov 25 2011, 03:03 PM
914 Guru Group: Members Posts: 5,817 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Costco has a steel one that I'm happy to own
Andyrew |
Nov 25 2011, 04:44 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
My friend has a costco one, and I have the harbor fright one (similar to whats listed above, They change the details on them out every few months to make them look different).
I LOVE my HF jack. Super high lift on it and very low profile. Pretty sure I paid ~90 for it. Not lightweight, no, but I wouldnt trust a lightweight version with my life. This steel, HEAVY duty one Im more inclined to (I still use stands though). |
Gint |
Nov 25 2011, 06:10 PM
Mike Ginter Group: Admin Posts: 16,083 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Sears only lifetime warranties Craftsman hand tools.
When I got to buy a low profile, high lift jack I'm probably going to spend decent money. I'm tired of cheap jacks myself. |
Mark Henry |
Nov 25 2011, 06:24 PM
Two post lift (IMG:style_emoticons/default/biggrin.gif)
(IMG:style_emoticons/default/confused24.gif) What??? it's hydraulic and it lifts the car.... I don't think they come in lightweight aluminium though.(IMG:style_emoticons/default/wink.gif) |
Jacob |
Nov 25 2011, 08:02 PM
Member Group: Members Posts: 131 Joined: 12-February 08 From: Mansfield, Oh Member No.: 8,705 Region Association: Upper MidWest |
2-ton service jack. Made in USA. 3-3/4" - 20". 96 lbs. $309.00
http://www.nationaltoolwarehouse.com/2-Ton...USA-P15106.aspx Don't know anything about them, just found it on the internet. |
Gint |
Nov 25 2011, 08:40 PM
I'm shopping for something like this:
http://www.nationaltoolwarehouse.com/2-Ton...ack-P56617.aspx What I'd really like to have is something more like this, but closer to $350-400: http://www.pelicanparts.com/catalog/shopca..._ACHyd1_pg1.htm |
Lo-Fi Version | Time is now: 10th June 2024 - 04:27 AM |
