Foil Engine Compartment Sound Mat/Pad, I need One |
d7n7master |
Aug 17 2004, 01:17 PM
Gary# Group: Members Posts: 663 Joined: 13-March 03 From: The O.C, Ca. Member No.: 421 |
Hi all,
I need a new engine comp. sound pad. I found this one @ PP. Are there other options??? (other than leaving it out completely.) Thanx, Gary Attached image(s) |
Dr Evil |
Aug 17 2004, 01:21 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
They were ~$60 on ebay new. maybe still are.
Howard |
Aug 17 2004, 01:26 PM
Incontin(g)ent Member Group: Benefactors Posts: 5,785 Joined: 24-July 03 From: Westlake Village, CA Member No.: 943 Region Association: None |
Bought what looks like the same one form this guy and received it last week. Haven't installed, but looks like a perfect fit. Price is right @ $37.50 including US shipping.
Foil |
Britain Smith |
Aug 17 2004, 02:13 PM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
Leave it out...it is a good way to absorb moisture and begin the rusting process.
-Britain |
bondo |
Aug 17 2004, 03:57 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
QUOTE(Britain Smith @ Aug 17 2004, 01:13 PM) Leave it out...it is a good way to absorb moisture and begin the rusting process. -Britain (IMG:style_emoticons/default/agree.gif) First make sure your rear window is sealing, then put insulation on the inside! |
jgiroux67 |
Aug 17 2004, 04:37 PM
Guitar Shredder Group: Members Posts: 593 Joined: 4-June 04 From: Turlock, CA Member No.: 2,157 |
Where can you get a sound/heat pad for the passenger compartment? I ripped out that 15lbs pad that came in it stock.
lapuwali |
Aug 17 2004, 05:44 PM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
From experiments done in other cars (not a 914), adding sound insulation on the "noisy" side is often more effective than adding it on the "quiet" side.
IMHO, if you're getting so much moisture into the engine bay that you're really worried about how much will be absorbed by a sound pad, you're going to have rust problems, anyway. Paint the firewall properly so the metal is sealed and put a sound absorbing pad on the engine side. It will make a much bigger difference than putting the same weight sound pad on the inside. |
Britain Smith |
Aug 17 2004, 05:59 PM
My car is an early '70 model and never came with a pad. But I don't understand why you would need one...I drive my car to work daily and have never thought it was too loud. It even has a Bursch exhaust.
-Britain |
d7n7master |
Aug 18 2004, 12:57 PM
I POR15'ed the whole engine compartment so I'm not concerned with moisture trapped in the pad. When I removed the old pad it was thrashed and heavy. I just bought a new pad off EvilBay for $30.- it only weighs 2Lbs. I also bought new engine bay seals from pp - but they didn't include the front seal. That suckz. So now I need to get creative... HomeDepot here I come.
(IMG:style_emoticons/default/ohmy.gif) I gotta get my engine back in - I'm havin' teener withdrawals. (IMG:style_emoticons/default/driving.gif) |
seanery |
Aug 18 2004, 01:25 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
I think Zois has the contact for the guy who cuts 'em.
tdgray |
Aug 18 2004, 02:39 PM
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
I agree with the don't put it back in crowd.
I took mine out , damn thing musta weighed 25-30 lbs. Nothing but a moisture trap. I am going to lay a nice thick bed of chipguard down and then paint over that. This is very similar to the coating they put inside of regular car doors to minimize sound transfer. I've done on a couple of car now with very good results. Good luck |
Joe Bob |
Aug 18 2004, 03:17 PM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
The guy that sells on ebay and PP makes them...really light. I took a stock one and had a pattern cut and sent it to the maker.....he sells the raw material ....enuf for a pair for about 30 bucks....his cut ones have nice bound edges.
I'm sure he will be at Ventura Autofest....goes under the ebay name of appbiz...he also does carpet kits. |
Lo-Fi Version | Time is now: 11th June 2024 - 08:17 AM |
