| mwyatt |
Jan 27 2012, 02:17 PM
Member ![]() ![]() Group: Members Posts: 85 Joined: 5-April 03 From: San Diego, CA Member No.: 516 Region Association: Southern California |
I recently installed a third brake light on my '74, for a total cost of around $20. I had a friend with a 914 that got rear ended by a pick up truck at a stop sign a few years ago, so I figured this light was worth adding (my friend was fine, his 914 needed some bodywork). In order to add a thrid brake light you will need to purchase the light itself, and you will need to have a drill and appropriate bits, wire connectors or a soldering iron, extra wire, and simple tools to remove the targa bar trim.
First, buy an LED strip, I bought this one from Pep Boys: ![]() Next remove the three pieces of aluminum trim from the back of your roll bar. I believe I removed the two vertical side pieces first. There is a screw on top and a nut underneath the fender, then they slide off (you may not need to loosen the nut underneath depending on how the trim was reinstalled in the past, it's a lot easier if you leave it loose). The horizontal center piece is held on by three clips, one in the middle and one at each side. The piece will pull off at these three points. Be sure to use gentle pressure because the piece bends and dents easily. Once removed, measure the horizontal piece and mark the center in pencil. Then find the center of the LED light. Clean the aluminum trim piece and then mount the LED strip to it, matching center to center (the LED strip that I used had an adhesive edge so it was simple to attach to the trim): ![]() Next, drill a hole (or two) in the trim for the wires from the LED strip. The smaller the better here, make the opening just big enough to pull the wires through. Drill slowly to protect the trim. I drilled mine at an angle to make it easier to hide the wires: ![]() Now, thread the wires through the trim piece so that they will not interfere with the clips. Make sure to pull them all to one side, and make it the side that the wires for your tail lights enter into your trunk (left on my car). I had wires coming from opposite ends of the LED I used, so I had to extend the wires on one side and pull them all to the left : ![]() ![]() ![]() You may now reinstall the horizontal trim piece with the LED. The hardest part is getting the clips to work with the wires running behind them, but it is possible: ![]() Run the ground wire from the LED to a ground wire in your trunk, and run the positive wire to the brake light wire in your trunk. On my '74 the brake light wire is a black wire with green stripes. Do a search if you're not sure which wire to use, there are some great resources on this site to help determine what each wire running to your tail lights is for. I had to add extra wire to the wires that came with the LED to get enough length. You can either solder them together or use wire connectors. Make sure to run the wire down the sail panel where it will be hidden when the trim is reinstalled, then underneath the engine compartment grill on the left and into the trunk. I used a special type of connector to tap into the ground wire and brake light wire (I forget the name of the connector, see pics): ![]() ![]() ![]() Reinstall the vertical side trim on the roll bar and you are done! Off: ![]() (it is almost hidden in daylight when off) ![]() On: ![]() Good luck with your own install! |
| Tom_T |
Jan 27 2012, 02:56 PM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
...or you can go buy this for a bit more with all of the connections set up for brake & emergency flashers....
http://www.ebay.com/itm/914-Multifunction-...=item256b01c044 No affiliation, don't know the vendor & I haven't used it - but looked like pretty good idea/product when I saw it on eBay earlier! |
| effutuo101 |
Jan 27 2012, 02:58 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,738 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California |
Nice work! That looks good.
| SirAndy |
Jan 27 2012, 03:18 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,565 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
| Tom |
Jan 27 2012, 08:55 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
That is a great modification and I hope it will keep folks from rear-ending you, and everything we can do to prevent that is good. Good job, and I hope it keeps you safe, thanks for posting this. (IMG:style_emoticons/default/smile.gif)
Tom |
| bigkensteele |
Jan 27 2012, 09:43 PM
Major Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,200 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States
I like it too. The last pic makes me think that it is pretty effective, right there in the line of sight of most cars/drivers. I would rather have that than the one that Tom posted, which isn't much higher than the brake lights.
| Dr Evil |
Jan 28 2012, 11:37 AM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,044 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
I recently installed a third brake light on my '74, for a total cost of around $20. I had a friend with a 914 that got rear ended by a pick up truck at a stop sign a few years ago, so I figured this light was worth adding (my friend was fine, his 914 needed some bodywork). In order to add a thrid brake light you will need to purchase the light itself, and you will need to have a drill and appropriate bits, wire connectors or a soldering iron, extra wire, and simple tools to remove the targa bar trim. First, buy an LED strip, I bought this one from Pep Boys: Next remove the three pieces of aluminum trim from the back of your roll bar. I believe I removed the two vertical side pieces first. There is a screw on top and a nut underneath the fender, then they slide off (you may not need to loosen the nut underneath depending on how the trim was reinstalled in the past, it's a lot easier if you leave it loose). The horizontal center piece is held on by three clips, one in the middle and one at each side. The piece will pull off at these three points. Be sure to use gentle pressure because the piece bends and dents easily. Once removed, measure the horizontal piece and mark the center in pencil. Then find the center of the LED light. Clean the aluminum trim piece and then mount the LED strip to it, matching center to center (the LED strip that I used had an adhesive edge so it was simple to attach to the trim): Next, drill a hole (or two) in the trim for the wires from the LED strip. The smaller the better here, make the opening just big enough to pull the wires through. Drill slowly to protect the trim. I drilled mine at an angle to make it easier to hide the wires: Now, thread the wires through the trim piece so that they will not interfere with the clips. Make sure to pull them all to one side, and make it the side that the wires for your tail lights enter into your trunk (left on my car). I had wires coming from opposite ends of the LED I used, so I had to extend the wires on one side and pull them all to the left : You may now reinstall the horizontal trim piece with the LED. The hardest part is getting the clips to work with the wires running behind them, but it is possible: Run the ground wire from the LED to a ground wire in your trunk, and run the positive wire to the brake light wire in your trunk. On my '74 the brake light wire is a black wire with green stripes. Do a search if you're not sure which wire to use, there are some great resources on this site to help determine what each wire running to your tail lights is for. I had to add extra wire to the wires that came with the LED to get enough length. You can either solder them together or use wire connectors. Make sure to run the wire down the sail panel where it will be hidden when the trim is reinstalled, then underneath the engine compartment grill on the left and into the trunk. I used a special type of connector to tap into the ground wire and brake light wire (I forget the name of the connector, see pics): Reinstall the vertical side trim on the roll bar and you are done! Off: (it is almost hidden in daylight when off) On: Good luck with your own install! Excellent job. I might just copy this in the future. The location of it is perfect for SUV view, and it does not block up any of the rear window (IMG:style_emoticons/default/thumb3d.gif) |
| mwyatt |
Jan 28 2012, 12:51 PM
Thanks for the feedback guys! I hope I helped someone out.
| Jacob |
Jan 28 2012, 07:44 PM
Member ![]() ![]() Group: Members Posts: 131 Joined: 12-February 08 From: Mansfield, Oh Member No.: 8,705 Region Association: Upper MidWest |
Nice work That looks great! I agree that it is great that it does not interfere with the rear window. Thanks for posting that!
| 913B |
Jan 29 2012, 12:39 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 887 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
Thats pretty cool, good job ! How visible is it in the daytime ?
| TC 914-8 |
Jan 29 2012, 12:59 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 848 Joined: 23-May 08 From: Sequim, WA Member No.: 9,090 Region Association: Pacific Northwest
I like it, nice job and in the final picture it looks very effective.
Is the LED strip mounted on the bottom of the trim piece? it's hard to tell but I cannot see it from the back (IMG:style_emoticons/default/confused24.gif) |
| EdwardBlume |
Jan 29 2012, 02:47 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,340 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California
Classic thread? (IMG:style_emoticons/default/beerchug.gif)
| 76-914 |
Jan 29 2012, 02:34 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,996 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Nice job. Someone else here did the same thing awhile back.
| TC 914-8 |
Feb 18 2012, 12:40 AM
I looked at my local AP store and they wanted $40 bucks for a 20" section of red LED strips. I found a 10' roll on Ebay for $12 bucks, came on the slow boat from China, not kidding. So anyway I followed the pics on the beginning of the thread and in less than an hour I had mine installed. Here is a picture with them powered up, I still have to wire them into the brake light circuit, but very simple and stealth solution to adding protection from Grama not paying attention, the kids behind me texting while driving.
Thanks mwyatt for the idea, I have more of the red LED strip available if any local folks want a piece. I'll put a better pict up tomorrow ![]() |
| MecGen |
Feb 18 2012, 08:23 AM
8 Easy Steps ![]() ![]() ![]() Group: Members Posts: 848 Joined: 8-January 05 From: Laval, Canada Member No.: 3,421 |
So anyway I followed the pics on the beginning of the thread and in less than an hour I had mine installed. Nice (IMG:style_emoticons/default/beerchug.gif) Good to see this, nothing more scary then stopping for a light then watching someone come up way too fast in the rear view mirror (IMG:style_emoticons/default/hissyfit.gif) Regards |
| 913B |
Feb 18 2012, 12:42 PM
Were those the self adhesive type, how wide was the strip, is it bright enought in the daytime ?
| Harpo |
Feb 18 2012, 02:41 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Could you please post the link to the ebay site where you got your LEDs?
Thanks David |
| Drums66 |
Feb 18 2012, 03:04 PM
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
.....Maybe more attention to the rear (IMG:style_emoticons/default/idea.gif)
(IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/shades.gif)(GET OFF THE PHONE!!!) |
| mwyatt |
Feb 18 2012, 03:25 PM
TC 914-8, nice job! Cool car too.
| abnrdo |
Feb 18 2012, 04:24 PM
Member ![]() ![]() Group: Members Posts: 399 Joined: 24-September 04 From: Panama City, FL Member No.: 2,820 Region Association: South East States |
Lo-Fi Version | Time is now: 27th November 2026 - 09:07 PM |
