saigon71 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,015 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region ![]() ![]() ![]() |
This piece of plastic was mounted on the rear edge of the floorpan at the engine bay on the drivers side. The one on the passenger side mush have fallen off due to rust.
Not looking for a concourse car here, but don't want to omit any pieces that will cause me problems down the road. Anyone run their car without these plastic flaps? ![]() |
EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
Unlike my time here on the world site, the flaps are there for a reason.
If you are in colder climates, you are probably fine. |
nathansnathan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None ![]() |
I can see the flaps making a difference in cooling. With the bottom of the car being so flat, the air just goes right by. With those there, the turbulence slows the air down and moves it about along the cooling fins below the engine. I'm going to install some on my early car, actually. Seems like particularly on the freeway, when head temps are higher and the air is going by faster that these would come into play.
Randal |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 ![]() |
Think they were put there by the Porsche engineers to create air disturbance over the cylinders to enhance cylinder cooling. If they are not there, then the air just flows straight past the cylinders.
I run them on my race car. |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
This piece of plastic was mounted on the rear edge of the floorpan at the engine bay on the drivers side. The one on the passenger side mush have fallen off due to rust. Not looking for a concourse car here, but don't want to omit any pieces that will cause me problems down the road. Anyone run their car without these plastic flaps? The pair of these parts introduces turbulence to the air flow under the car, aiding engine cooling. You should have them. The Cap'n |
hot_shoe914 |
on ramp passer ![]() ![]() ![]() ![]() Group: Members Posts: 3,807 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None ![]() |
QUOTE You should have them. The Cap'n 'nuff said. |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
Sorry, but I am on my 3rd 914, and I have never seen that part in my life...
If I hadnt read the responses from above, then I would have said it wasnt from a 914. |
MLedesma |
Member ![]() ![]() Group: Members Posts: 52 Joined: 13-October 06 From: Elizabeth, CO Member No.: 7,036 Region Association: Rocky Mountains ![]() |
Early cars don't have them. My 71 and 72 don't, but my 74 does.
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,824 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
It's a worthwhile retro fit to any early car.
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,245 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
flash914 |
Member ![]() ![]() Group: Members Posts: 124 Joined: 1-January 11 From: littlerock CA Member No.: 12,554 Region Association: Southern California ![]() |
I have a 70' how about someone putting a picture up with them inplace so that we can see how hard it would be to instrall them on our early cars? Thanks Gordon
Tom_T |
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California ![]() ![]() |
This piece of plastic was mounted on the rear edge of the floorpan at the engine bay on the drivers side. The one on the passenger side mush have fallen off due to rust. Not looking for a concourse car here, but don't want to omit any pieces that will cause me problems down the road. Anyone run their car without these plastic flaps? The pair of these parts introduces turbulence to the air flow under the car, aiding engine cooling. You should have them. The Cap'n (IMG:style_emoticons/default/agree.gif) .... and in any part of the USA & elsewhere for that matter - just takes one hot summer day! (IMG:style_emoticons/default/sad.gif) These air flaps/diverters were added in the 73 MY due to the engines running hotter with leaner mixtures & higher smog controls, as well as the 70-72 standing problems with hot egine bays causing vapor lock (fuel pump relocation under the fuel tank in F trunk for 75-76 MY was another "factory fix", as well as a service bulletin to relocate the 70-74 FP up under the steering rack at the front pan/firewall next to the tunnell access hole). |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,185 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
Here's my 71 retrofitted with air dams.
Attached image(s) ![]() ![]() |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
I made sure they were on my build. They create a low pressure field under the engine allowing more air to be pulled through the grill.
(IMG:https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-ash2/163598_1750835736594_1409883264_1936232_6564102_n.jpg) |
Cap'n Krusty |
This piece of plastic was mounted on the rear edge of the floorpan at the engine bay on the drivers side. The one on the passenger side mush have fallen off due to rust. Not looking for a concourse car here, but don't want to omit any pieces that will cause me problems down the road. Anyone run their car without these plastic flaps? The pair of these parts introduces turbulence to the air flow under the car, aiding engine cooling. You should have them. The Cap'n (IMG:style_emoticons/default/agree.gif) .... and in any part of the USA & elsewhere for that matter - just takes one hot summer day! (IMG:style_emoticons/default/sad.gif) These air flaps/diverters were added in the 73 MY due to the engines running hotter with leaner mixtures & higher smog controls, as well as the 70-72 standing problems with hot egine bays causing vapor lock (fuel pump relocation under the fuel tank in F trunk for 75-76 MY was another "factory fix", as well as a service bulletin to relocate the 70-74 FP up under the steering rack at the front pan/firewall next to the tunnell access hole). I would be interested in seeing this "service bulletin'. I worked at a dealership and took all the available factory training classes through 1974, and I've never seen or heard of it. It's not in the TSB books I have, either. The Cap'n |
saigon71 |
Thanks for all the responses - great info! (IMG:style_emoticons/default/beerchug.gif)
Will be placing a WTB add for the passenger side. I hope I left enough of a lip on the rebuilt pan for bolts! |
ThePaintedMan |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,887 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States ![]() ![]() |
Thanks for all the responses - great info! (IMG:style_emoticons/default/beerchug.gif) Will be placing a WTB add for the passenger side. I hope I left enough of a lip on the rebuilt pan for bolts! I think that Rich Dauenhauer has a couple for sale, FYI. I was looking at them myself. To echo everyone else, Porsche wouldn't have put anything on these cars that didn't belong! |
saigon71 |
I have a 70' how about someone putting a picture up with them inplace so that we can see how hard it would be to instrall them on our early cars? Thanks Gordon The plastic air dam itself is threaded on my car. Find the parts, drill four holes on each side where the rear firewall meets the floorpan. Shouldn't be too bad if nothing is in the way. (IMG:style_emoticons/default/biggrin.gif) |
Eric_Shea |
QUOTE I have a 70' how about someone putting a picture up with them inplace so that we can see how hard it would be to instrall them on our early cars? 3 M5x.8x10 with nuts, washers and lock washers per flap. Drill the rear edge of the floor pan where it extends into the engine bay. Purdy simple actually. |
saigon71 |
Have one on the way from a 914world member. Thanks for all the info. Measured the drivers side placement, drilled holes yesterday & mock fitted air dam on the passenger side:
![]() ![]() Bob |
Lo-Fi Version | Time is now: 4th July 2025 - 09:03 PM |
