Rear Control Arm Pivot Shaft Failure, Almost got the shaft... |
bulitt |
Feb 9 2012, 03:11 PM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
So, pulled my control arms to change out the rubber bushings and they looked fine from the outside and the pivot shaft surface looked fine so for a moment I almost left them alone.
The procedure as documented by Eric in the classic section looked easy enough and since I had already purchased the bushings I decided to change them out. Both shafts had heavy rust on the outside ends. Looks like the bushings were wore, allowing water to penetrate between the shaft and bushing. Approx 120 degrees of one shaft was eaten away to the point I could stick a screwdriver into the shaft. This would have failed sometime in the future. |
ww914 |
Feb 9 2012, 03:19 PM
914 Convert Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California |
I am certainly not surprised. In a partial restoration of my car I am finding that anything I take apart, needs to be cleaned, lubricated, painted or simply replaced. Guess that comes with 35 plus year old cars.
Lo-Fi Version | Time is now: 7th June 2024 - 11:12 PM |
