WTB: Vacuum Elbow and thermal switch, For 74 D-Jet |
CG-914 |
Feb 21 2012, 09:42 PM
Member Group: Members Posts: 326 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California |
I need the Vacuum Elbow for the AAR oe part #:022 133 083
And I also need the Thermal switch: Thank you! |
Bleyseng |
Feb 22 2012, 09:40 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
order the elbow new from AA as I have seen only one used one that wasn't a leaker.
CG-914 |
Feb 22 2012, 10:24 AM
914werke |
Feb 22 2012, 10:31 AM
"I got blisters on me fingers" Group: Members Posts: 10,120 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Do you mean the "stacked" elbow?
JawjaPorsche |
Feb 22 2012, 10:35 AM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
I just went to Auto Atlanta and they said the part was no longer available.
Here is what their webpage says: Elbow for auxiliary air regulator M EA0 098 793 Sorry but that part is no longer available, but there may be other options available. Please call us at 800-792-4944 Hope this helps. Terry order the elbow new from AA as I have seen only one used one that wasn't a leaker. AA = Auto Atlanta? |
JawjaPorsche |
Feb 22 2012, 10:36 AM
pilothyer |
Feb 22 2012, 11:00 AM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
I need the Vacuum Elbow for the AAR oe part #:022 133 083 And I also need the Thermal switch: Thank you! I have just recently obtained 4 of the thermo switches, I put them all in a sub zero temperature environment for days. I took them out one at a time and quickly checked for continuity........none of them ever showed any at all. I think they would be good at about 20 below zero, but I will most likely never be in that environment. This said I doubt my cold start valve will ever be used. The cold start valve has battery voltage applied to it during cranking only and the thermo sensor supplies ground to it only when the temp is extremely cold. In light of this I doubt I would never waste the money on the thermo switch or the cold start valve......In addition the AAR source side should be connected to filtered air at the air cleaner and the other side to the cold start valve housing....no elbow required. |
Strudelwagon |
Feb 22 2012, 01:12 PM
Member Group: Members Posts: 411 Joined: 11-October 08 From: interior, British Columbia Member No.: 9,633 Region Association: Canada |
I bought rubber elbows from CIP1 (california Imports) VWC-021-129-639
they used them on the bus. Cheap, Cheap! SW |
jimkelly |
Feb 22 2012, 01:43 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
this one?
Attached image(s) |
JeffBowlsby |
Feb 22 2012, 02:47 PM
914 Wiring Harnesses Group: Members Posts: 8,527 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
This from Brad Anders site on the activation temps for the thermo switches:
311 906 161 : -12 to -18 deg. C / 10 to 0 deg. F 311 906 161 A : 0 to -10 deg. C / 32 to 14 deg. F 311 906 161 B : -2 to -8 deg. C / 28 to 18 deg. F 311 906 161 C : -6 to -14 deg. C / 21 to 7 deg. F |
jimkelly |
Feb 22 2012, 04:33 PM
jeff - good point - thanks
per brad anders site - the C appears to be the right TS for your engine - what are the odds http://members.rennlist.com/pbanders/DJetParts.htm |
pilothyer |
Feb 22 2012, 05:15 PM
This from Brad Anders site on the activation temps for the thermo switches: 311 906 161 : -12 to -18 deg. C / 10 to 0 deg. F 311 906 161 A : 0 to -10 deg. C / 32 to 14 deg. F 311 906 161 B : -2 to -8 deg. C / 28 to 18 deg. F 311 906 161 C : -6 to -14 deg. C / 21 to 7 deg. F Jim.........Have you checked this one out? What temp does it take to get continuity between the terminal spade and the body? |
CG-914 |
Feb 23 2012, 12:47 PM
Did you jim?
jimkelly |
Feb 23 2012, 02:16 PM
no
pilothyer |
Feb 23 2012, 08:09 PM
jimkelly |
Feb 23 2012, 08:41 PM
i don't know about his troubles - but this one is free to him if he wants it.
i just need his address. jim |
pilothyer |
Feb 23 2012, 08:59 PM
what is the test procedure? According to Bran Anders Site This sensor Part # 311 906 161 C should show continuity between the terminal spade and the body of the sensor @ 21 to 7 deg. F So....put in the freezer section of your refrigerator ( mine maintaines about 5 below zero F.) Keep it in overnight, take it out and very quickly measure for continuity....(it doesn't take long for the temp to come up so you'll have to be quick......This is a reverse thermister in that the resistance goes up as the temp goes up as opposed to, let's say the head temp sensor where resistance goes down as the temp goes up. |
jimkelly |
Feb 24 2012, 09:53 AM
i'll give it a try
jimkelly |
Feb 24 2012, 12:14 PM
i gotta run - but i put my set up in the freezer about an hour ago - and recently -continuity happend : )
video coming... 23 seconds of continuity out of freezer. https://www.youtube.com/watch?v=GOc_8JjeQ_E Attached image(s) |
CG-914 |
Feb 24 2012, 02:05 PM
Lo-Fi Version | Time is now: 2nd June 2024 - 08:06 PM |
