Transmission woes, This looks bad to me. Initial inspection. Experts? |
bfrymire |
Mar 16 2012, 06:09 PM
Salsaholic Group: Members Posts: 590 Joined: 1-August 04 From: Sunnyvale, CA Member No.: 2,431 Region Association: Northern California |
Ok. After the last autocross, I noticed a howling from the car when in second gear. Not good. So, I pulled the drain plug, and this is what the magnetic pickup has on it.
I would assume this is not normal and bad. (IMG:style_emoticons/default/sad.gif) Thoughts? |
Dr Evil |
Mar 16 2012, 06:55 PM
Send me your transmission! Group: Members Posts: 23,000 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Means nothing. How is the transmission shifting? If you have never used it, now would be a good time to pull the stack and inspect. All plugs look like that. It probably has not been cleaned since Regan was in office.
bfrymire |
Mar 16 2012, 08:07 PM
Means nothing. How is the transmission shifting? If you have never used it, now would be a good time to pull the stack and inspect. All plugs look like that. It probably has not been cleaned since Regan was in office. Shifts fine. No grinding. I am looking for your dvd now to see about pulling the stack. (I have misplaced it since the last time I looked at it...) -- brett |
Lo-Fi Version | Time is now: 23rd May 2024 - 06:02 AM |
