> Cleaning up my trans
Harpo
post Mar 22 2012, 04:26 PM
What is the best way to clean up my trans. I believe the case is magnesium is there a cleaning agent that I should stay away from?
Once it is clean what should I use to protect the trans and help keep it clean?
Thanks
David
Scott S
post Mar 22 2012, 04:48 PM
Small Member
I used simple green and lots of tooth brush sized wire brushes in varios stiffnesses. The brushes came in 3 packs at nearly every local auto parts stores.
After it dried for a few days I went over the whole thing again with just a new set of brushes (dry). Looks clean, but not over restored/polished.
(sorry for the crappy pic)
Jeffs9146
post Mar 22 2012, 04:53 PM
Ski Bum
I use "Awsome" from the $ store! Works great!
Just spray it on, scrub it a bit, let it sit for a while and pressure wash it off....repeat!
slothness
post Mar 22 2012, 05:05 PM
It's business time
Everyone has an opinion on this. I used name brand EZ Off oven cleaner and a hard nylon bristle brush with a damp rag, my trans was coated in heavy crispy grime and it cleaned it beautifully. Then coat it with a liberal amount of Tectyl (waxy type spray on coating).
Dr Evil
post Mar 22 2012, 05:07 PM
Send me your transmission!
Tectyl is crap. You need to reapply too often. See my 31 pages of note for my opinions on this (IMG:style_emoticons/default/smile.gif)
wingnut86
post Mar 22 2012, 05:14 PM
...boola la boo boola boo...
Doc,
There ya go again, understated as always. Stop beating around the damn bush and tell us what you realy mean...
(IMG:style_emoticons/default/happy11.gif)
slothness
post Mar 22 2012, 05:22 PM
It's business time
Yeah, I only mentioned something specific because the notes kinda say don't clean your tranz. If you do then search other forums for methods, or paint it. My trans was so caked with "road caca" cleaning it was a must cuz the last thing I want is overheating with all the money I put into that thing. The front of my trans is painted black, the intermediate plate and tail cone are Tectyl, reapplication is no biggie.
Dr Evil
post Mar 22 2012, 05:27 PM
Pressure washing bad, tectyl bad, clean with Eazy Off good, paint good.
Simple?
Jeffs9146
post Mar 22 2012, 05:30 PM
Ski Bum
(IMG:style_emoticons/default/agree.gif) If you are NOT opening it up to service it!
bulitt
Achtzylinder
QUOTE(Dr Evil @ Mar 22 2012, 07:27 PM) *
Simple?
Pressure washing ok right before your clinic????
EdwardBlume
post Mar 22 2012, 05:34 PM
If doing a hand job, use a 2 inch round wire brush on a drill...
Puns galore.
Harpo
post Mar 22 2012, 06:14 PM
Yes I plan to rebuild at the Ohio trans clinic. quarter power wash was something that I was considering.
Thanks
David
Dr Evil
post Mar 22 2012, 06:23 PM
If right before clinic, pressure wash ok. It is the water that gets in and sits that is the reason.
a914622
I have used this method for a long time. Jacobs paint stripper and a power washer will make it look like new. I have a bunch of trannys in storage and before i put them away I clean them and put on a coat of LP3. Its the waxy shipping grease. sprays on like a thin honey and dries to a wax.
If its going in use I like the machine gray engine paint. Or black.
jeff
Ps Jacobs also cleans pistons
JmuRiz
post Mar 22 2012, 08:30 PM
Would something like Gibbs penetrating oil work to protect it after cleaning? Isn't tact what some 911 guys use on their fans?
Dr Evil
post Mar 23 2012, 06:48 AM
The Gibbs oil is something I am not familiar with, but Gibbs does make a protectant that some use (the name escapes me).
The only reason to use exotic preparations on your case is if you do not plan on cleaning it completely (IMG:style_emoticons/default/confused24.gif) If you remove the grease and dirt, just paint the dang thing. I am using a product from POR-15 that looks like brushed aluminum.
Steve73
post Aug 11 2012, 09:24 PM
Photographer/Shade Tree Mechanic
What about painting it with Silver caliper paint. It's designed for high heat and is "chemical" resistant.
Drums66
post Aug 11 2012, 09:44 PM
914 Rudiments
.....Wire wheel & drill....Fuch,no....power wash easy/off or simple green.....
speaking from decades of experience!!
speed metal army
post Aug 11 2012, 09:48 PM
Waiting for the rain to stop...
I used some s100 cycle cleaner, works kickass! A brush in the spots the goo was super heavy helped too.
Richard Casto
post Aug 12 2012, 07:14 AM
Blue Sky Motorsports, LLC
QUOTE(Dr Evil @ Mar 22 2012, 07:07 PM) *
We all have our opinions regarding Tectyl (or equivalent). Short of painting, I challenge people to suggest a better solution. I have done some long term testing with...
* Tectyl
* Gibbs
* No coating (bare metal after cleaning)
Tectyl wins hands down. It is not perfect and doesn't last forever, but provides good protection. Painting is great, but everyone can't afford (or even want) to do it. So they need other options.
To the OP question. Others have made good suggestions. I prefer non acidic/caustic solutions, but they can work if you don't go crazy. I would only pressure wash if you plan on opening it up right afterward. Be careful with using wire brushes. I don't use steel wire and even then only scrub by hand. It really comes down to putting in the time. Dental style picks are good for cleaning the hard to reach places.
Richard
- Lo-Fi Version Time is now: 5th July 2025 - 09:59 PM
