Fan hub |
Fan hub |
wndsrfr |
Apr 12 2012, 07:10 PM
Senior Member Group: Members Posts: 1,430 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Found the smoking gun on my engine meltdown........fan hub got loose after alternator belt failed & wrapped around ground cable. Sudden jerk snapped one bolt & sheared dowel pin allowing the fan to wobble. Said wobble confused the injection system which has magnets in the fan--resulting in lean running at 80mph on interstate and frying the exhaust valves & seats.
Sooo....I'm looking for a good fan hub & spacer and at least one bolt. Attached image(s) |
Rods914 |
Apr 12 2012, 08:56 PM
Rods914 Group: Members Posts: 18 Joined: 24-June 03 From: Peoria, Ill 61615 Member No.: 853 Region Association: Upper MidWest |
Found the smoking gun on my engine meltdown........fan hub got loose after alternator belt failed & wrapped around ground cable. Sudden jerk snapped one bolt & sheared dowel pin allowing the fan to wobble. Said wobble confused the injection system which has magnets in the fan--resulting in lean running at 80mph on interstate and frying the exhaust valves & seats. Sooo....I'm looking for a good fan hub & spacer and at least one bolt. John, I sent you an email. Rod Bell (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 29th May 2024 - 06:00 AM |
