Elliot_Cannon |
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,922 Joined: 26-March 03 From: Orange County Ca Member No.: 480 Region Association: None ![]() |
Hi,
I am restoring my 73 914 and have a few (more) questions. Can I leave off the bellows and flappers or will I need them? I will have the engine built to 2.2 and will be using webers. Can I do away with the expansion chamber on top of the fuel tank? I would like to mount a wider tire (205 50 15). What wheel offset do I need to mount these tires under stock fenders? Cheers, Elliot (IMG:style_emoticons/default/icon14.gif) (IMG:style_emoticons/default/icon14.gif) (IMG:style_emoticons/default/icon14.gif) |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
You MUST leave the flapper in place for the oil cooler. I take and place the oil cooler flap under the two sides of the oil cooler tin... so it cant raise up. I would have to shoot a pic to explain it better. Anyway.. the flap for the oil cooler must be secured down over the cooler.
You can remove the other flap...with the rod on it and the bellows. You live in SoCal.. so warmup wont be a big issue for you like it would be for sombody in the northeast. You must run a stock 914 wheel (Mahle/Fuchs/Pedrini) or som variation of aftermarket for the 914 to get a 205/50/15 under the stock fenders. Basically a 15x5.5 wheel or a 15x6 or 15x7... B |
Lawrence |
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 1,661 Joined: 5-February 03 Member No.: 244 Region Association: None ![]() ![]() |
I'm quoting from George Hussey.
The flaps are installed both for warm-up and for engine cooling. It is necessary for all engines to reach operating temperature as quickly as possible and then, when at that temperature, air cooled engines need to get as much cooling air over the cylinder fins through the oil cooler as possible. The cooling flaps do both of these things. First, when the engine is cold, the termostat bellows are collapsed, pulling hard on the wire connected to the flaps. This holds the flaps closed in the following way: the right (passenger's) flap is up and against the cylinder cover. This allowes all air flow to blow over the cylinders and out the engine without passing through the oil cooler. The left (driver's) flap is vertical, blocking all air from entering the cylinder cover cavity. Second, as the engine warms up, the thermostat bellows relax gradually, relieving the tension on the wire until the flaps are fully open. The right (passenger's) flap now completely covers the oil cooler, laying horizontally while dividing the cooling chamber in two. This now allows cooling air to flow simultaneously over the cylinder fins and forces air through the oil cooler. The left (driver's) flap is horizontally up against the top of the cylinder cover, allowing all cooling air to flow over the cylinder fins. Without these bellow flaps installed the engine takes too much time to warm up, and after warming up, it will run hot, as the cooling air is not forced through the oil cooler. -Rusty |
tahoward |
Member ![]() ![]() Group: Members Posts: 87 Joined: 30-December 02 From: Middletown, OH Member No.: 52 ![]() |
Mmm...I need pics on this one. Did all cars come with these?
MJHanna |
Does this 911 make my butt look big? ![]() ![]() ![]() Group: Members Posts: 806 Joined: 23-January 03 From: Lowry Crossing, Texas Member No.: 185 ![]() |
QUOTE(Elliot Cannon @ May 9 2003, 08:55 AM) Can I do away with the expansion chamber on top of the fuel tank? Yes,you can remove the plastic piece and have just the gas cap. (IMG:style_emoticons/default/beer.gif) |
need4speed |
Member ![]() ![]() Group: Members Posts: 339 Joined: 11-April 03 From: Arroyo Grande, CA Member No.: 564 ![]() |
Type 1 VW's have em too. And these days, MOST of them have been removed by people who thought they knew better than the engineers who designed these cars in the first place.
Lo-Fi Version | Time is now: 3rd July 2025 - 06:00 PM |
