Motor support Torque, Simple for "You" I know |
bandjoey |
Jun 19 2012, 06:30 PM
bandjoey Group: Members Posts: 4,929 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Rear Transmission support using 911 supports - Haynes shows 14.5lb torque
Front (at the side of the bar) motor support bolts - Haynes show 21.7lb torque RIGHT?? Nothing is shown for the rubber motor mounts? New solid rubber from the Bird Torque?? Thanks Guys. I'm under the car waiting. (IMG:style_emoticons/default/smash.gif) |
Cap'n Krusty |
Jun 19 2012, 07:28 PM
In general, 8mm bolts call for 14.7 ft/lbs, but 18-19 is OK. 10mm fasteners use about 35 ft/lbs, and 12mm use 56 or so. Do that and you'll be OK.
The Cap'n |
Lo-Fi Version | Time is now: 16th June 2024 - 11:44 PM |
