| Daiberl |
Aug 23 2012, 09:44 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 575 Joined: 22-June 09 From: Seattle, WA Member No.: 10,497 Region Association: Pacific Northwest |
I finally had time to check my LE out and why the car is running hot. The spark plug shows that the car runs lean, adjustment knob at ECU is full rich already. MPS checked and leaks 3.5 down from 10in so based on pbanders fine. No vacuum leaks, flaps at oil cooler are open, timing fine.
What can cause the car to run too lean? Would a wrong CHT cause this, I changed the CHT when I dropped the engine last time and didn't drive the car on longer trips. |
| Dustin |
Aug 24 2012, 01:15 AM
Member ![]() ![]() Group: Members Posts: 117 Joined: 19-August 10 From: Woodland Hills, CA Member No.: 12,072 Region Association: None |
The knob on the ecu only adjusts mixture when the TPS is in the idle circuit.
check your fuel pressure? |
| Bartlett 914 |
Aug 24 2012, 07:41 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I finally had time to check my LE out and why the car is running hot. The spark plug shows that the car runs lean, adjustment knob at ECU is full rich already. MPS checked and leaks 3.5 down from 10in so based on pbanders fine. No vacuum leaks, flaps at oil cooler are open, timing fine. What can cause the car to run too lean? Would a wrong CHT cause this, I changed the CHT when I dropped the engine last time and didn't drive the car on longer trips. The knob only affects the idle. The CHT is critical and could be a source of the problem. Adding resistance will richen the mixture. |
| JeffBowlsby |
Aug 24 2012, 09:05 AM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,306 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
TS1 can also be unplugged to give a slight richness enhancement
| Daiberl |
Aug 24 2012, 11:45 AM
| JeffBowlsby |
Aug 24 2012, 01:31 PM
TS1 is the Air temp on the air plenum
| Daiberl |
Aug 27 2012, 10:19 AM
Ok, finally I had some time yesterday to check the car again, I unplugged TS1 and I rechecked timing and vacuum lines. Car is still running very hot and after 15 minutes my oil temp gauge was showing high oil temp again. Any other ideas???
Attached thumbnail(s) |
| JeffBowlsby |
Aug 27 2012, 10:40 AM
Thats a normal oil temp reading for the stock guage Juergen, I wouldnt worry about that. To really test it you'll need to get an accurate temp guage or pyrometer to know the exact temp values.
ANd to check for mixture, an exhuast gas analyzer. Maybe a shop can do that for you? |
| JRust |
Aug 27 2012, 12:48 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,317 Joined: 10-January 03 From: Albany Oregon Member No.: 129 Region Association: Pacific Northwest
Yeah I wouldn't sweat your temps there. I would buy one of those diptick temp gages to get an accurate read. I think you are fine there. Mine will go past the P on the temp gage in really hot weather on the highway. If that is as high as it goes don't worry about it. If you take it out & it is past the P approaching the red. Then you need to change something (IMG:style_emoticons/default/smile.gif) .
| Daiberl |
Aug 27 2012, 07:01 PM
Ok, then I will give it another try and will report back how high the temperature is going. I plan to do an oil change before, currently I'm on non-synthetic but plan to switch, maybe that also helps to keep the temperatures down.
| 914itis |
Aug 27 2012, 08:18 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
Ok, finally I had some time yesterday to check the car again, I unplugged TS1 and I rechecked timing and vacuum lines. Car is still running very hot and after 15 minutes my oil temp gauge was showing high oil temp again. Any other ideas??? My oil temp reads the same sometimes in above 90 degree temps. but it takes more than 15 minutes to get there; at least an hour of highway driving. |
| Dave_Darling |
Aug 27 2012, 09:03 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,355 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Is the cooling system complete? Do you have the flaps inside the cooling tin? Any debris in the fan? Any mouse nests under the tin?
--DD |
| Daiberl |
Aug 27 2012, 09:44 PM
Is the cooling system complete? Do you have the flaps inside the cooling tin? Any debris in the fan? Any mouse nests under the tin? --DD Engine was rebuild, no mouse nests or debris, flaps are installed and in the open position at the moment to make sure the thermostat is not the issue. |
| PancakePorsche |
Aug 29 2012, 03:30 AM
Member ![]() ![]() Group: Members Posts: 236 Joined: 29-July 11 From: Southern California Member No.: 13,373 Region Association: None |
I raised my fuel pressure to 32 psi and 2 steps colder plugs. The new junk they call gasoline has a lot to do with the problem. ECU is not calibrated for the alcohol now present. As others mentioned, you need to trick the ECU to increase delivery. If the stripe on plug ground electrode is 50 percent or more away from tip use colder plugs.
| ChrisFoley |
Aug 29 2012, 07:41 AM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,031 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
Oil temp isn't a good indicator of fuel mixture anyway.
| Bleyseng |
Aug 29 2012, 09:12 AM
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,037 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
I finally had time to check my LE out and why the car is running hot. The spark plug shows that the car runs lean, adjustment knob at ECU is full rich already. MPS checked and leaks 3.5 down from 10in so based on pbanders fine. No vacuum leaks, flaps at oil cooler are open, timing fine. What can cause the car to run too lean? Would a wrong CHT cause this, I changed the CHT when I dropped the engine last time and didn't drive the car on longer trips. What plugs are you running? Oil gauge reading is normal so how are you determining that you are running lean? What MPS, ECU do you have? Is the MPS a OEM unit or rebuilt? I am in town mostly for the next 3 weeks so maybe a can help you. |
| TJB/914 |
Aug 29 2012, 09:51 AM
Mid-Engn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,498 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest
George Hussey @ AA just fixed my slightly lean engine issue with a part I bought from him 10-years ago. I found it in my junk drawer and installed it a few days ago and corrected all lean issues. Check out my post with George on 914-Club site and read what happened. I suspected a lean engine idle at low RPM's & lived with it but after installing a "wehrle" part #039.971.762a that adds 270 ohms to the head temp sensor it increased the duration of injecting with a alightly richer mixture for more power & better idle when fully hot.
Guys, I felt the engine smooth out and run better than ever on my 2.0 liter F.I. Raby # 9550 camshaft with Raby LE-180 heads. Amazing tech advise from George. I understand AA sells them, don't know how much $$ but it worked for me. Tom Attached thumbnail(s) |
Lo-Fi Version | Time is now: 10th July 2026 - 06:54 PM |
