kbrunk1 |
Brunk ![]() ![]() Group: Members Posts: 180 Joined: 13-November 11 From: Dallas,Texas 73 2.0 FI Member No.: 13,778 Region Association: South East States ![]() |
Well she is getting close.
I checked the gear oil after sitting for 25 years and it is real low. I wanted to change it while it was warm but am afraid there is not enough if I get to drive this sucker. Saw some SAE 80 at walleyworld and was wondering if folks use it? Also what is wrong with 30SAE Casteroil or Vavoline 30SAE? for the engine? Owners manual says SAE30 for engine and SAE transmission oil MIL-L-2105B or MIL-L205 SAE 90 for gearbox. Maybe fill it up with Wallworld SAE80 and then heat it up and change it to what the forum recommends? ???? |
championgt1 |
Don't embarrass me Filmore! ![]() ![]() ![]() ![]() Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest ![]() |
Oil=Brad Penn 20W50
kbrunk1 |
Found this on Pellican
As a result of this lowering of ZDDP content, and as of this posting, the only choices I am aware of that provide adequate ZDDP Protection include (in no particular order): Brad Penn Racing Oils (same as the old Kendall from the '70s); SWEPCO 306; Redline; Royal Purple; Castrol GTX High Mileage; and Mobil 1 V-Twin MC 20w-50. added 9/16/2007 Mobil 1 MX4T 10w40 Royal Purple Max Cycle 20w50 Amsoil m/c Harley V-twin 20w50 Castrol Syntec "Classic" 20w50 Added 9/22/2007 Valvoline VR-1 20W-50 -it is marked "Non-Street Legal". |
mrholland2 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 753 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California ![]() |
None of the oil you can get at Wally's will have enough Zinc. (Just went through this on here). SOME parts places have it, but you need to specifically find HIGH Zinc oils for the engine.
Well she is getting close. I checked the gear oil after sitting for 25 years and it is real low. I wanted to change it while it was warm but am afraid there is not enough if I get to drive this sucker. Saw some SAE 80 at walleyworld and was wondering if folks use it? Also what is wrong with 30SAE Casteroil or Vavoline 30SAE? for the engine? Owners manual says SAE30 for engine and SAE transmission oil MIL-L-2105B or MIL-L205 SAE 90 for gearbox. Maybe fill it up with Wallworld SAE80 and then heat it up and change it to what the forum recommends? ???? |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Doc Evil recommends the cheapo 80W or 90W gear oil, changed regularly.
--DD |
mrholland2 |
monkeyboy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None ![]() |
Yes GL-5. That shouldn't be too hard to find.
As for the engine oil, you may have to order it in. My personal favorite is the Joe Gibbs aircooled oil. You can order it from Jegs. It is designed for aircooled engines. |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Call some local v8 type, hot rod speed shops. most of them Carry it. I have one in Tulsa who is the only dealer in okie land.
Brian_Boss |
Member ![]() ![]() Group: Members Posts: 324 Joined: 3-June 03 From: Dallas, TX Member No.: 781 ![]() |
If you don't want to mess with having it shipped, Zim's in Bedford has Brad Penn.
Lo-Fi Version | Time is now: 13th June 2024 - 02:03 AM |
