Check your fuses |
Check your fuses |
pete000 |
Oct 21 2012, 12:55 AM
Senior Member Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
Had a bit of a problem. I think I hooked up my rear trunk light backwards.
The wiring melted due to a 25 am fuse installed instead of the proper 8 amp. Can any one tell me if the rear trunk light is on the same fuse as the license plate light fuse #8 ? I never checked the fuses when I purchased this car. (IMG:style_emoticons/default/hissyfit.gif) What a mess !!!!! 1970 914 |
toolguy |
Oct 21 2012, 03:11 AM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
that should have been 2 gray wires [power] and 1 brown [grd]. . and yes the 2nd gray wire goes back to the plate lights. .
pete000 |
Oct 21 2012, 10:15 AM
Where does the brown ground wire go from the trunk light?
I am trying to trace these back. The gray wire at the fuse box is a little melted, but not that bad. |
Lo-Fi Version | Time is now: 9th June 2024 - 06:58 PM |
