7TPorsh |
7T Porsh ![]() ![]() ![]() ![]() Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California ![]() ![]() |
I was pulling a caught old wire out of the engine compartment and noticed the motor moved a little.
I grabbed the accelerator linkage bracket and pushed/pulled the engine side to side and noticed the front of the motor moving left and right almost two inches. Probbaly explains the clunk I hear occasionally. I got under the car...sort of...and managed to get some pics. Are there bolts that are supposed to be in here? ![]() ![]() |
Bartlett 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest ![]() |
I was pulling a caught old wire out of the engine compartment and noticed the motor moved a little. I grabbed the accelerator linkage bracket and pushed/pulled the engine side to side and noticed the front of the motor moving left and right almost two inches. Probbaly explains the clunk I hear occasionally. I got under the car...sort of...and managed to get some pics. Are there bolts that are supposed to be in here? yup |
7TPorsh |
Where can I source these? Can't find it at Pelican...
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
Looks like the early model of engine support.
PET catalog says that the bolt part # is: 900 074 138 01 or M10 X 70 mm. http://www.autoatlanta.com/porsche-parts/p...arts/119-00.php You should be able to find that bolt at an Ace hardware. I wouldnt do any autocross that way ;-) Chances are that the only thing keeping the engine from sliding around is the engine tins. Stu |
Woody |
Sandbox Rabblerouser and head toilet scrubber ![]() ![]() ![]() ![]() Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region ![]() |
Looks like the early model of engine support. PET catalog says that the bolt part # is: 900 074 138 01 or M10 X 70 mm. http://www.autoatlanta.com/porsche-parts/p...arts/119-00.php You should be able to find that bolt at an Ace hardware. I wouldnt do any autocross that way ;-) Chances are that the only thing keeping the engine from sliding around is the engine tins. Stu (IMG:style_emoticons/default/agree.gif) |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,765 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() ![]() |
Uh. Wow!
At least we know that there is a safe failure mode! Zach |
Jesco Reient |
Member ![]() ![]() Group: Members Posts: 135 Joined: 18-July 12 From: Western Washington Member No.: 14,690 Region Association: Pacific Northwest ![]() |
Uh. Wow! At least we know that there is a safe failure mode! Zach Or he is really lucky (IMG:style_emoticons/default/smilie_pokal.gif) |
ScoopLV |
Senior Member ![]() ![]() ![]() Group: Members Posts: 545 Joined: 7-September 12 From: Las Vegas Member No.: 14,897 Region Association: Southwest Region ![]() |
I'm going with "Really, REALLY Lucky." Slam on the brakes during an "oh, crap" moment and get a big surprise coming through the firewall at 80 mph.
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,118 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
It happened to me once too. Not the same way though. Passenger side engine support bar bolt came loose. Car started running wonky because wires were pulling loose. (IMG:style_emoticons/default/blink.gif)
7TPorsh |
so what's holding it in? the two bolts at the back of the tranny?
I better check the bar too.... |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,990 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
Lo-Fi Version | Time is now: 31st July 2025 - 06:51 AM |
