deep sump, need screen @ pickup? |
machina |
Nov 4 2004, 02:02 PM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
Just got my deep sump from aircooled.
I'm trying to solve my oil starvation problem. In looking at the screen that goes in the sump, seems like the design of the screen plate may impede or slow down oil available to the pickup. Would it be a bad idea to leave the screen out? There is an external filter in the system. |
eeyore |
Nov 4 2004, 02:09 PM
Senior Member Group: Members Posts: 889 Joined: 8-January 04 From: meridian, id Member No.: 1,533 Region Association: None |
Slightly OT -- can you post some pictures of the sump & screen?
machina |
Nov 4 2004, 05:28 PM
here is a pic from someones website. I'll take some shots after I get it installed.
Attached image(s) |
ArtechnikA |
Nov 4 2004, 05:48 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
the screen is there to protect the oil pump...
Brett W |
Nov 4 2004, 06:04 PM
Advanced Member Group: Members Posts: 2,856 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None |
Toss the screen. When you run this dry sump I would not run any more than the stock amount of oil. There is no reason for it. One problem I see with that mounting system is the mounting "strap" goes across the main oil feed for the deep sump. The proper way to mount a deep sump is to machine it for a mounting system like the beetles and then mount that way.
Lo-Fi Version | Time is now: 10th June 2024 - 08:40 PM |
