| tadink |
Dec 12 2012, 02:50 PM
Member ![]() ![]() Group: Members Posts: 379 Joined: 28-December 09 From: Napa Member No.: 11,181 Region Association: Northern California |
Hi guys -
did a search on wheel spacers and got millions of hits but no answers....so I'll post this up. Where do you find good wheel spacers, and what are the pro's and con's of doing the various options? for the width I'm looking for - it seems there is a "bolt on" that does not need new wheel studs, or the spacers that have longer wheel studs passing thru them. I've gone with a 5-lug drilled into the 4 lug hubs.... I was surprised at the weight of the 2" spacers 'bolt on', like 6+ lbs each?! Currently I'm leaning towards the 54MM, Weltmeister Turbo Star Wheel Spacer - found a pair on paragon for $144.....compared to $146 EACH for the bolt on version on the bird site. thoughts and knowledge sharing very appreciated! cheers td |
| Eric_Shea |
Dec 12 2012, 02:56 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
What wheels? What offset? What fenders? 1" and 2" is ambiguous and misleading for those searching (as you did) for spacers.
No possible answers without knowing what it is you're "looking for". (IMG:style_emoticons/default/wink.gif) |
| tadink |
Dec 12 2012, 03:02 PM
What wheels? What offset? What fenders? 1" and 2" is ambiguous and misleading for those searching (as you did) for spacers. No possible answers without knowing what it is you're "looking for". (IMG:style_emoticons/default/wink.gif) AHHH, point taken. I have 10 spoke 17" 996 wheels front and back, fronts are 7, rears are 9" I believe. The flares are not on the car but are AIR wide GT flares, so I don't expect there will be clearance issues. We had the wheels up against the hubs and measured for clearance, so ~2" in the rear and ~1" in the front will work out just fine I think. Not really looking for advice on how wide, but given 1" and 2" spacers +/-, what are the options? thx td |
| Eric_Shea |
FWIW... I like 944 spacers. I've stacked a few and custom machined them for the desired thickness:
(IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos-a.xx.fbcdn.net-1110-1355346176.1.jpg) |
| tadink |
Dec 12 2012, 03:05 PM
FWIW... I like 944 spacers. I've stacked a few and custom machined them for the desired thickness: (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos-a.xx.fbcdn.net-1110-1355346176.1.jpg) WOW! that is ARTWORK! You are talking hub-centric, yah? I've got stock 914 4 lug hubs drilled for 5-lug, not sure that approach will work? <---- clearly I'm lost and way out of my depth, trying to learn here.... thx td |
| SirAndy |
Dec 12 2012, 03:06 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,560 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Currently I'm leaning towards the 54MM, Weltmeister Turbo Star Wheel Spacer - found a pair on paragon for $144.....compared to $146 EACH for the bolt on version on the bird site. Street driving only or do you plan to do some track time? If track time is in your future, the bolt on "spacers" are *not* legal with any racing organization. Longer studs are easy to obtain and installed and the spacers for them (like the 944 spacers above) are much lighter and simple to install and change. (IMG:style_emoticons/default/driving.gif) |
| underthetire |
Dec 12 2012, 03:08 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
I bought some from this guy
http://www.ebay.com/itm/Wheel-Hub-Centric-...d62&vxp=mtr VERY good quality and very good aluminum alloy (6061) |
| SirAndy |
Dec 12 2012, 03:14 PM
As you can see, i very much prefer the longer studs. Obviously, you don't have to use them that long (100mm in my case), you can run shorter ones if you don't need that much spacers ...
(IMG:http://www.914world.com/bbs2/uploads/post-179-1157311360.jpeg) (IMG:http://www.914world.com/bbs2/uploads/post-179-1182813810.jpg) (IMG:style_emoticons/default/driving.gif) |
| tadink |
Dec 12 2012, 03:38 PM
Currently I'm leaning towards the 54MM, Weltmeister Turbo Star Wheel Spacer - found a pair on paragon for $144.....compared to $146 EACH for the bolt on version on the bird site. Street driving only or do you plan to do some track time? If track time is in your future, the bolt on "spacers" are *not* legal with any racing organization. Longer studs are easy to obtain and installed and the spacers for them (like the 944 spacers above) are much lighter and simple to install and change. (IMG:style_emoticons/default/driving.gif) thanks - re: track time - only DE events and AX are intended, mostly street time. TD |
| SirAndy |
Dec 12 2012, 03:40 PM
only DE events and AX are intended, mostly street time. TD Bolt on adapters will be illegal to use for DE (and technically also for AX) ... (IMG:style_emoticons/default/popcorn[1].gif) |
| Eric_Shea |
Dec 12 2012, 03:42 PM
QUOTE I've got stock 914 4 lug hubs drilled for 5-lug So you'll have 914 calipers and solid rotors under all of that meat? (IMG:style_emoticons/default/ohmy.gif) Doable but, as Andy mentions, it really depends upon your intended use. When you mentioned the Sheridan kit and the wide rubber, I thought you might be racing the car but, with drilled 4 stuff, it appears to be more of a street car. The rears are fine being drilled but again, you're limiting yourself to 914 components attached to 935 wheels and tires. (IMG:style_emoticons/default/wink.gif) (914 rear hubs only allow 914 CV joints). If your fronts are drilled 914 rotors then you can really only work with 914 calipers and solid rotors. You can use a 911 caliper without spacers if it's an early 914 rotor but there's no real gain. Again, all this can be done if all you want is a cool looking street car and you don't plan to put a motor in it that is commensurate to the body kit and the tire size. Let us know what you're plans are and we can help guide you so you don't waste money along the way. (IMG:style_emoticons/default/beer.gif) |
| Eric_Shea |
Dec 12 2012, 03:45 PM
QUOTE Sheridan kit Sorry... misread... the A.I.R. flares. |
| jmmotorsports |
Dec 12 2012, 04:43 PM
Member ![]() ![]() Group: Members Posts: 308 Joined: 15-August 06 From: Kelso,Wa. Member No.: 6,658 Region Association: Pacific Northwest |
iuseHAND R BOLTON TYPE NEVER HAD A PROBLEM WITH THEM
JERRY |
| matthepcat |
Dec 12 2012, 04:46 PM
Meat Popsicle ![]() ![]() ![]() Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
I used 100mm studs and 944 spacers. They are light and very high quality. You can find them at the junk yard if your lucky.
| Woody |
Dec 12 2012, 05:01 PM
Sandbox Rabblerouser and head toilet scrubber ![]() ![]() ![]() ![]() Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
| tadink |
Dec 12 2012, 05:18 PM
QUOTE Let us know what you're plans are and we can help guide you so you don't waste money along the way. (IMG:style_emoticons/default/beer.gif) "don't waste money along the way?!" (IMG:style_emoticons/default/av-943.gif) ultimately, as time and money allow - I'd like to do more track, but for now the goal is to have a decent street car with good handling and some of the cool big boy look. So, compromise is the order of the day - I've been able to assemble the kit so far fairly reasonably.....totally agree that I'm limited by the strength of the stock 914 bits on her at present and realize that I will have to upgrade at some point to stronger CVs, etc if I find the right engine....2.7L or higher. But that is a whole 'nuther slippery slope.... Now, about these 944 spacers - am I correct in seeing that it looks like they are about an inch each and the guys are adding a pair for ~2in spacer? I'll dig around and see what I come up with - are they just laying in the dirt next to abandoned 944s waiting for a new home? td |
| SirAndy |
Dec 12 2012, 05:54 PM
Now, about these 944 spacers - am I correct in seeing that it looks like they are about an inch each and the guys are adding a pair for ~2in spacer? I vaguely remember them being a bit less than an inch wide ... (IMG:style_emoticons/default/idea.gif) |
| bulitt |
Dec 12 2012, 08:00 PM
Achtzylinder ![]() ![]() ![]() ![]() Group: Members Posts: 4,189 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
I bought some from this guy http://www.ebay.com/itm/Wheel-Hub-Centric-...d62&vxp=mtr VERY good quality and very good aluminum alloy (6061) I agree, used them on my rears. I have 5 stud 100mm rears and just pressed the studs out of these spacers and they then slid right over my studs on the hub. |
| JFJ914 |
Dec 13 2012, 11:15 AM
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States
only DE events and AX are intended, mostly street time. TD Bolt on adapters will be illegal to use for DE (and technically also for AX) ... (IMG:style_emoticons/default/popcorn[1].gif) Is that a local rule on the west coast? I checked with the Tech people in the Peachstate (Georgia) PCA region, and they have no idea why you can't use them, they are very popular in installing late offset wheels on early 911's and 944's. We use the PCR's and there is nothing in them banning them. |
| SirAndy |
Dec 13 2012, 12:24 PM
Is that a local rule on the west coast? That is a good question. Maybe PCA has changed their mind of late? It's been 10 years since i was last dinged for running bolt on adapters and now they rarely look for them during tech inspections. I switched to longer studs and slip on spacers some 8 years ago and haven't paid much attention to the rules since. (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 2nd November 2026 - 08:55 AM |
