| 442nd914s |
Dec 15 2012, 06:05 PM
Member ![]() ![]() Group: Members Posts: 139 Joined: 25-July 12 From: KC Suburb Member No.: 14,718 Region Association: None |
Getting ready to install the engine and cant remember where this wire goes to. It looks like it goes into the hole next to the drivers side heat port.
On a side note: fuel lines. I have original plastic lines coming from the firewall. The bigger one (10mm) is that the feeding line that goes to the filter. Thanks for ur help Attached thumbnail(s) |
| Jeffs9146 |
Dec 15 2012, 06:41 PM
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
It looks like the one that goes from the alt to the back of the starter main + from the battery!
| 914itis |
Dec 15 2012, 06:57 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
Yep, same place as the bla k wire .
| 76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,878 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
yep. the derk area on that sheathing will line up with the grommet where it turns under.
| Tom |
Dec 15 2012, 07:10 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
(IMG:style_emoticons/default/agree.gif) and nice looking engine, clean!
I did notice that your fuel line to the fuel pressure regulator looks a little short, may be the camera angle. Yours line looks to be about about 6 inches, mine is closer to 12 inches. Easier to check now than after engine install. Tom |
| 442nd914s |
Dec 15 2012, 07:51 PM
(IMG:style_emoticons/default/agree.gif) and nice looking engine, clean! I did notice that your fuel line to the fuel pressure regulator looks a little short, may be the camera angle. Yours line looks to be about about 6 inches, mine is closer to 12 inches. Easier to check now than after engine install. Tom Thanks for noticing my clean engine. I just had it rebuilt to a 2056 cc and took the time to clean & paint all the tin, intake manifolds & mic parts. I also had the alternator & starter rebuilt. I may have to pull on the cable in question cause it seems to be +/- 2" short of the starter bolt. More pictures to come of the engine. |
| 914itis |
Dec 15 2012, 08:17 PM
The cable should reach of routes properly . There should be ahole on the back metal thin to route the cable
Lo-Fi Version | Time is now: 16th April 2026 - 07:36 PM |
