1.7l big bore kit? 1972? |
jdlmodelt |
Dec 26 2012, 06:42 PM
James D. Lane Group: Members Posts: 345 Joined: 30-November 12 From: Colorado Member No.: 15,210 Region Association: Southwest Region |
what is the biggest bore I can take my 1.7l to without major remods to the crankcase? recommendations?
thanks, j |
Cap'n Krusty |
Dec 26 2012, 07:41 PM
I'm thinking 96mm slip-ins. Gonna make a ton of heat though, and it's unlikely to run very well with D-jet EFI, even if you fiddle with it. You'll have to calculate the compression ratio and shim the barrels to compensate for the big increase, and open up the cylinder heads to accept the new diameter. You DO NOT want to run over 8.2:1. 93s make for a hundred more CCs and your FI will be fine.
The Cap'n |
euro911 |
Dec 26 2012, 09:43 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
How about 94mm slip-ins, John? ... 1911cc?
ThePaintedMan |
Dec 27 2012, 12:22 AM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
euro911 |
Dec 27 2012, 01:52 AM
My goof. 94mm would be 1832cc with the stock 66mm crank. 96mm would be 1911cc.
Even increasing from 90mm to 93mm (1793cc using stock 1.8L barrels and pistons) you would need to fly-cut the 1.7L heads. |
ThePaintedMan |
Dec 27 2012, 08:54 AM
My goof. 94mm would be 1832cc with the stock 66mm crank. 96mm would be 1911cc. Even increasing from 90mm to 93mm (1793cc using stock 1.8L barrels and pistons) you would need to fly-cut the 1.7L heads. Thats what I thought. Sorry to hijack the OP's thread (IMG:style_emoticons/default/smile.gif) |
Cap'n Krusty |
Dec 27 2012, 10:54 AM
If you use 94 mm pistons, you CANNOT use the OE spec units without replacing the crank and rods with 2 liter parts. I suppose there may be 94mm aftermarket pistons made for the 1.7/1.8 crank and rods, but I've never seen them. And, yes, any increase in bore will require opening up the heads.
The Cap'n |
Al Meredith |
Dec 27 2012, 11:44 AM
Senior Member Group: Members Posts: 960 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
I have a set of NPR (Nippon Piston Ring) 96MM pistons and cylinders for a 1.7 L making 1911 CC. The cylinders are sized for a 1.7 head and they don't require flycutting. The cylinders are therefore thin on top. I do not have a set of rings but they are still available from Performance as rings for big bore kits. 2MM / 2MM / 5MM. If anyone is interested get in touch. Al
Cupomeat |
Dec 27 2012, 11:54 AM
missing my NY 914 in VA Group: Members Posts: 1,336 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
If it were me, I'd bite the bullet and go for the 2056 size engine.
You'll NEVER regret it once it is done. I know, not the question asked. As for the answer, you can go the 96mm slip-ins but the sealing surface at the head is VERY small, So I'd either get the one for the 1,8l and have the heads opened or (BETTER) get some 1.8l heads (they have bigger valves). |
jdlmodelt |
Dec 27 2012, 11:43 PM
OK. So what can I do to the stock 1.7l to improve HP without all the bore upgrades? Can I put in the same displacement but slightly bump up the compression? I'm putting a 2.0l out of my 76 for now but I'm planning ahead when the 2.0l in the 76 and the 1.7l back in the 72
brant |
Dec 27 2012, 11:59 PM
914 Wizard Group: Members Posts: 11,640 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
OK. So what can I do to the stock 1.7l to improve HP without all the bore upgrades? Can I put in the same displacement but slightly bump up the compression? I'm putting a 2.0l out of my 76 for now but I'm planning ahead when the 2.0l in the 76 and the 1.7l back in the 72 nice to see a colorado guy on here... the problem with the 1.7 is that is costs just as much to rebuild it with 70hp (correctly) as it does to rebuild a 2.0 motor with 105hp. your best economical bet would be SSI exhausts if you really want to open the engine, then a cam and carbs but at that point, its only 200$ more to put in the 2ltr crank and rods... your 1.7 heads and valves are really the limiting factor and rebuilding those with bigger heads are about the same price as rebuilding a set of 2.0 heads with bigger valves.... so stock 2.0 heads are cheaper than big valves on your cores. for the money.. finding a running $1000 2.0 motor gives you 90 - 95 hp and costs about 1/5th the cost of rebuilding... if you do open it up to rebuild, most people decide its worth adding the displaceemnt hp at that point for relatively the same costs... living with a running 1.7 gives up 15-20hp but costs $5-6K less....... |
jdlmodelt |
Dec 28 2012, 08:31 AM
OK. So what can I do to the stock 1.7l to improve HP without all the bore upgrades? Can I put in the same displacement but slightly bump up the compression? I'm putting a 2.0l out of my 76 for now but I'm planning ahead when the 2.0l in the 76 and the 1.7l back in the 72 nice to see a colorado guy on here... the problem with the 1.7 is that is costs just as much to rebuild it with 70hp (correctly) as it does to rebuild a 2.0 motor with 105hp. your best economical bet would be SSI exhausts if you really want to open the engine, then a cam and carbs but at that point, its only 200$ more to put in the 2ltr crank and rods... your 1.7 heads and valves are really the limiting factor and rebuilding those with bigger heads are about the same price as rebuilding a set of 2.0 heads with bigger valves.... so stock 2.0 heads are cheaper than big valves on your cores. for the money.. finding a running $1000 2.0 motor gives you 90 - 95 hp and costs about 1/5th the cost of rebuilding... if you do open it up to rebuild, most people decide its worth adding the displaceemnt hp at that point for relatively the same costs... living with a running 1.7 gives up 15-20hp but costs $5-6K less....... Thanks fellow Coloradan! |
brant |
Dec 28 2012, 08:52 AM
we have a local colorado yahoo group too
you ought to join we get together for drives and sometimes wrenching too here is the site: colorado where in the state are you? |
sean_v8_914 |
Dec 28 2012, 09:10 AM
Chingon 601 Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
have had success with the 1911 at no more than 8.5 on L Jet. requires FI tuning to get AFR correct.
the 1.7 responds well to increase in compression to 8.5 when combined with the SSI or 2.0 HEs and a Bursch type 4-2-2-1 tuned collector the 1.7 HE has small ID pipe if you are bold you can match port the exhaust a little. 1.7 heads have small ports and valves, thats why they run forever |
thelogo |
Dec 28 2012, 10:06 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
[quote name='sean_v8_914' date='Dec 28 2012, 07:10 AM' post='1791776']
have had success with the 1911 at no more than 8.5 on L Jet. requires FI tuning to get AFR correct. P the 1.7 responds well to increase in compression to 8.5 when combined with the SSI or 2.0 HEs and a Bursch ty the 1.7 HE has small ID pipe if you are bold you can match port the exhaust a little1.7 heads have small ports and valves, thats why they run forever [/ Hell. Yeh I'd rather have 15/30 less horshpower An last forever the have a failure rate of over 90% w.2.0 heads Lack of bore spacing and aircooled do not go together I always use 91octane if I need more pep Shout out to the CHEAp S O B |
Dave_Darling |
Dec 29 2012, 12:55 AM
There have been 96mm P&C sets made for the 1.7s, which give you a 1911cc displacement. They are very thin to fit into the 1.7 heads.
The same kits made for the 1.8 give the same displacement, but are thicker. The 1.7 heads need to be cut to fit them. If you're going up in displacement, that's not a bad way to go. Except for the 73 CA-only version, all of the 1.7s had relatively high compression (I think either 8.2:1 or 8.6:1) and were rated at 80 HP DIN. They require premium-grade fuel already; going up further in compression is probably not a great idea unless you can figure out how to make sure you don't get detonation. The Tangerine Racing headers are good for something like a 10% HP bump. Make sure you're sitting down when you look at their price--but it's the biggest "bolt on" HP adder you can find, and they are absolute works of art. Chris also has an option for heat (probably just enough to de-fog the windshield) but most headers lose all semblance of heat. Which is an issue for some of us. The 2056cc motor (a 2.0 crank and rods, plus the 96mm P&C kit that is made for the 2.0 motor) will bolt together with the 1.7 case, but again the heads will need to be cut to fit the cylinders. Everyone I know who has one of those motors is happy with it... For a while, at least, until the urge for more power hits. (IMG:style_emoticons/default/wink.gif) --DD |
Lo-Fi Version | Time is now: 9th June 2024 - 07:47 PM |
