PDXMike |
Slowly Learning ![]() ![]() Group: Members Posts: 112 Joined: 20-December 10 From: Portland, OR Member No.: 12,501 Region Association: Pacific Northwest ![]() |
I opened up my previously chattering clutch today. The pressure plate is all nicked up. I guess I shouldn't be surprised, engaging the clutch felt pretty much the same way this looks. But given that the clutch disk isn't THAT worn, I don't see how this is possible. It looks like somebody went at it on purpose with a cold chisel.
Is it just likely that a previous PO replaced the disk and put it back together like this? Is there something else wrong that needs to be addressed? ![]() ![]() Mike |
messix |
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest ![]() |
WOW!!!
never seen one that looks like that... did you look at the pilot bearing? |
PDXMike |
I haven't pulled the flywheel yet, so I'm not sure about the pilot bearing. There's nothing obviously wrong with it, none of the needle bearings fell out or anything like that.
toolguy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,276 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California ![]() ![]() |
Isn't it curious that the marks go across the pressure plate, rather than circular. . . I wonder if a PO decided the pressure plate needed 'adhesion marks' in some attempt to keep the clutch plate from slipping ???
DBCooper |
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California ![]() |
I've never seen that either, so I'm curious too. Chattering can produce a radial pattern, but not like that, and certainly not that amount of damage. I'd suspect the needle bearings too, but where's the corresponding damage in the friction material on the disc? Yeah, I'm curious.
Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
Looks like maybe a tooth from the flywheel got in between the PP and clutch and was rolling as the clutch was engaged, or something like that!
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
Looks like FOD (Foreign Object Debris). You should replace the pilot bearing while your in there. A bad or missing pilot can cause chattering but the scars look like FOD.
aircooledtechguy |
The Aircooledtech Guy ![]() ![]() ![]() Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest ![]() |
The damage looks like someone tried to re-new the wear surface of the pressure plate with a 6" grinder free-hand; seriously. I wouldn't put it past a dumb P.O.
It could also be that at some point the center broke out of an old clutch and it banged around in there as the same dumb P.O. tried to figure out what all the noise was when he cycled the pedal. To save $$$, he only replaced the broken part and left the pressure plate for the next guy. . . I've seen this happen on a beetle with a Chinese clutch kit. . . |
JRust |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,317 Joined: 10-January 03 From: Albany Oregon Member No.: 129 Region Association: Pacific Northwest ![]() ![]() |
I agree it looks like you had something foreign stuck between the plate & Clutch. Every time you engaged it would move to a different spot? That is pretty wild though (IMG:style_emoticons/default/confused24.gif) . I can't say I have ever seen one like that either. Anything fall out when you pulled it? That clutch disc is sure missing some meat on the one lip. Looks like a good 3/8" has worn off the one edge. If you need anything I have a few spares. Your welcome to them if you drive down to pick them up (IMG:style_emoticons/default/smile.gif)
DBCooper |
I can't accept that pressure plate damage happened when that disc was in place. Nothing that could do that much damage to the metal pressure plate surface would leave the disc friction material intact. I'd bet that damage occurred previously and then it was reassembled with a new friction disc. That would explain the chatter, and how else could that friction disc escape being chewed up a lot more than it is?
Mike Bellis |
Buy a new clutch kit. Usually come with pilot bearing and throw-out bearing. (IMG:style_emoticons/default/beerchug.gif)
What does the flywheel look like? I'm not sure I would trust it. (IMG:style_emoticons/default/sad.gif) |
wndsrfr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,454 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region ![]() ![]() |
Geez I love puzzles & can't imagine what caused the dings in that pressure plate. the yellow paint mark on the clutch disk is likely a junkyard mark, probably a similar one on the PP also. Post up a pic of your flywheel when you get a chance...look carefully at the step available between the wear surface and the hub to see if it's beyond refinishing. Then go in with a new PP & clutch disk assembly....don't forget to get a new flywheel o-ring that's tucked inside where the crank mates up and also the plastic cup that the release lever pivots on.....
jasons |
Jackstand Extraordinaire ![]() ![]() ![]() ![]() Group: Members Posts: 2,011 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None ![]() |
Yellow paint on friction disk smells like junkyard parts. Maybe those parts were thrown together on the cheap when a previous disk was worn to the rivets. It wouldn't surprise me if the PO left the pilot bearing out altogether. I had a car with a blown pilot bearing and it had a bad chatter.
Lo-Fi Version | Time is now: 3rd July 2025 - 01:14 AM |
